Sponsored by BimmerWorld
Old 12-07-2010, 06:14 PM   #1
autograff323
My Ride: One nice BMW
Best place to buy my rear bushings?
I'm doing my rear trailing arm Bushings the lower and upper bushings and ball joints. I just wanted to get a feel of where is the best place to buy the things I need.
autograff323 is offline   Reply With Quote
Old 12-07-2010, 06:35 PM   #2
McSpeed
My Ride: 2005 ZHP TT Stg 1
Autohausaz had best pricing when I ordered mine a few months ago.
Are you doing the install?
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 12-07-2010, 07:06 PM   #3
autograff323
Yeah I'm doing the whole suspension front and back.
Old 12-07-2010, 11:07 PM   #4
McSpeed
Cool - I just did that - just have to reattach the rear subframe now. I wanted to keep it civilized (no hammers, blowtorches or chisels allowed) so I ended up making a lot of press tools with a dremel and some washers
Old 12-08-2010, 11:11 AM   #5
autograff323
Any help that you can give me so I dont have to buy the press tools and the puller tools would be great.
Old 12-08-2010, 11:32 AM   #6
McSpeed
Sure I have pictures too. I can rent you my stuff if you want - putting it all together again would be a big ordeal. When all was said and done, if I could start over, I think I would've bought the BMW special tools (from Koch Tools instead of the more expensive Baum where possible) even though they cost hundreds of dollars. It'd be worth it vs. the time I spent getting mine right. The only BMW special tools I bought were the one for the big diff bushing and the Bimmerworld one for the RTABs. I then used parts of the RTAB tool for almost every other bushing.
If that sounds interesting I could probably rent within a week or two.
Also you might want to doublecheck with realoem.com beforehand to make sure a 2005 330i shares the bushing p/n's with yours.
Old 12-08-2010, 12:43 PM   #7
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
We carry the PowerFlex line of bushings so let us know if you need help.
Old 12-08-2010, 12:52 PM   #8
McSpeed
Yeah - to the OP - note that I am going with the yellow Powerflex subframe bushings, which are easy to install, so my tools were only designed to press out the OEM subframe bushings; not press them in. If you wanted to put in OEM subframe bushings you'd have to do some pusher/puller fabrication to make it work.
