Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 4.82 average. Display Modes
Old 12-11-2010, 03:53 PM   #1
karumph1
My Ride: 325i
e46 drivers side door lock cylinder problem solved
If your drivers side door lock spins 90 degrees in either direction and won't lock/unlock, then this information is probably exactly what you need.
Read:
My 325i keyless entry broke, so I had been using the key to manually unlock my car. I took it to the shop, and the mechanic wanted $500 dollars to fix it...$200 for the part, $300 for labor. I looked around on the internet and couldn't find any answers on how to fix it or what was wrong, but I did find out how to take out the cylinder myself. I took it out and realized that the only part that was broken was a tiny metal piece that connects the lock cylinder to the part that unlocks the car (i believe its called the actuator?). So i'm going to post a picture of what broke and I plan to go to a junkyard and take this tiny metal piece out of a wrecked 3 series. I'm 100% sure this is the only part that is broken, and this fix will be an incredibly easy DIY and probably cost me about $20 tops. Hopefully this guide helps out another bmw owner with the same problem, because apparently theres lots of people on the internet who had the same problem I did.
Uploaded with ImageShack.us
New:
Ok, so I ordered the part for $29 on Ebay from osco_ltd and it took about a week to get here. I fixed the broken part and reassembled the lock. I installed it and it works perfectly. It took me a little while to figure out how to put the lock back together properly, and I had the most problems figuring out how the spring works. Here is the explanation on how to re-assemble it.
go to the post by "ledfut" with the attached pictures.
http://forums.bimmerforums.com/forum....php?t=1552024
karumph1 is offline   Reply With Quote
Old 12-11-2010, 04:53 PM   #2
jfoj
My Ride: 330CiC, M5, X5
http://cgi.ebay.com/ebaymotors/BMW-E...Q5fAccessories
Unfortunately I have only seen these pieces listed on ebay outside the US.
Looks like about $29 US??
Old 12-11-2010, 05:02 PM   #3
h4nh
My Ride: 05' 325i
I had the same issue. I bought a whole new lock cylinder for about 150 at the dealer
h4nh is offline   Reply With Quote
Old 01-28-2011, 04:54 PM   #4
mikeyh1015
My Ride: Bmw 04' 330ci coupe
does this also apply to my 04 330ci?
mikeyh1015 is offline   Reply With Quote
Old 02-03-2011, 10:23 PM   #5
2003 325i
My Ride: '03 Orient Blue 325i
I bought a new cyl at the dealer too... coded from Germany... I'm afraid to take my old one apart to find something that could've only cost 30 bucks...
Old 02-16-2011, 09:23 PM   #6
scooterjcx
My Ride: 325i
So i bought my 01 325i five speed this week and i love it, what didnt go threw my head was to check if the key works, so yah my remote and door keylock dont work, so i cant lock my car! after lots and lots of searching i found on ebay where i can buy the repair kit, but i bought the cheap one with no instructions, searched some more on ebay and found someone that was offering a instruction video with the kit so i wrote to the guy saying that i want to see the video before i get the kit to see if i can do it myself or have the stealership do it so he sent me the link i hope this helps answer all of your questions.
glad to help on my first post
e46fanatics is the bomb!
scooterjcx is offline   Reply With Quote
Old 02-21-2011, 08:01 AM   #7
anhtu402
My Ride: 2002 BMW 325XI
YOU ARE AWESOME!!!
Who did you buy the kit from? Are you still waiting?
I need to fix mine.
anhtu402 is offline   Reply With Quote
Old 02-22-2011, 11:45 AM   #8
scooterjcx
My Ride: 325i
this is the part i got and yes i"m waiting for its arrival
Old 02-22-2011, 06:43 PM   #9
TruongCT
My Ride: 2003 330CI
Does anyone have diy instructions how on to get that out of your door to replace the kit? thanks
TruongCT is offline   Reply With Quote
Old 02-23-2011, 12:47 AM   #10
anhtu402
I have not done it yet nor seen any pictures on here. However, I have read that it's pretty easy to get the cylinder out. Read here (http://forum.e46fanatics.com/showthr...ght=key+unlock) , I'm planning to do this soon as my key does not open the front door, it just turns to the right/left without any spring action to bring it back to up/down position.
Old 02-23-2011, 01:04 AM   #11
anhtu402
http://forum.e46fanatics.com/showthr...+lock+cylinder
Found it, how to remove the cylinder..
Old 02-23-2011, 01:46 AM   #12
dr2
My Ride: Black 325i 2003
thank you for this thread, mine just broke today
Black E46 325i 2003
dr2 is offline   Reply With Quote
Old 02-23-2011, 11:23 AM   #13
anhtu402
I am having trouble taking this cylinder out. Is this the hole that I can for find the hex screw to release the cylinder?
I can see the cylinder has been broken, but just cant seem to see the hex screw to unscrew it to take it out.
Sent from my PC36100 using Bimmer App
Old 02-23-2011, 11:39 AM   #14
anhtu402
Okay .. I finnally found the.hex screw to the far left of the hole.
Old 03-04-2011, 01:23 PM   #15
scooterjcx
My Ride: 325i
got the parts today installed in 5 minutes now my lock works lock unlock open and close windows
joy
Old 04-27-2011, 11:04 PM   #16
junkiekommando
My Ride: 02 330i, 91 318is
Thanks! im gonna replace mine in a few days. just waiting for the repair kit.
-Carlos
junkiekommando is offline   Reply With Quote
Old 04-27-2011, 11:17 PM   #17
KnightroExpress
My Ride: 2002 330ci
Aww, man! I wish I had seen this thread a few days ago! Ordered a whole new cylinder from my indy. Ah well, at least I'll know for next time.
KnightroExpress is offline   Reply With Quote
Old 05-10-2011, 01:08 PM   #18
p19blo
My Ride: 318i
Hey guys, new here, i read this thread when redoing my lock cylinder, took apart fine, put back together fine, but now when key is left in lock ( i havent put back in my car yet, its stationary position is that if you were locking the door, and if i turn it to go to the position of unlocking the door, it does not get that far, it just goes to the position it would if you were taking the key out or putting the key in.... any ideas why its stationary position is the locking position and why it wont let me go to the unlocking position... any help would be appreciated
So im not double posting
*EDIT*
The reason for my above problem is the kit i bought came with 2 parts and i have to pick one or the other, the different between these 2 were the inner slots the key cylinder were in were different to the other spare, so i swapped them round and voila problem solved.
p19blo is offline   Reply With Quote
Old 05-10-2011, 01:20 PM   #19
Shanealan
My Ride: 325i No heatbeat yet
Thank you sooo much for the info. Mine was broke when I bought the car.
Shanealan is offline   Reply With Quote
Old 06-04-2011, 06:55 PM   #20
DBMW
My Ride: 2000 BMW 323i
Lightbulb Cylinder lock
I just want to thank everyone who contributed to this thread. Ever since I bought my 2000 BMW 323i a few weeks ago, I had not been able to lock the car. The key did not work on the driver's side and it also did not lock the car electronically. I was driving to work and the mall and leaving it unlocked to make it easy for a car thief to have his way. Thanks to your post, I can happily say that I was able to repair the lock myself.
I had called the dealer and they said the lock would be $111.00 + $200 for labor So I decided to go to a nearby junkyard. They removed the lock cylinder from a BMW in their yard. Unfortunately, or fortunately for me, the long rod that connects to the lock was broken and it was the only one they had. The guy at the place said that it was probably the same rod that was broken on mine and since I had not taken mine apart to check, I took it as fact. While at the yard, I dismantled the part to see how it was put together. They were impressed that I knew how to take it apart (I only knew thanks to the video of how to put it back together on this thread ) I was disappointed and asked the guy if I could take the part home and he agreed since he would not be able to sell it broken.
I got home and began to remove the one on my door. I was scared at first, because I could tell that the previous owner had attempted this already. I found this out when I realized he had replaced the allen screw holding the cylinder with a basic phillips screw. I looked inside with a flashlight and saw that the rod was intact. I removed the lock cylinder and compared it to the one I had brought home. It turned out that the part that was broken on mine, was intact on the junkyard one. I switched the parts and very carefully reassembled. The spring was the hardest part, but a pair of small pliers did the trick. When I was done the lock looked new. I put it back in and now it works fine
I can finally sleep knowing my car is locked.
THANKS, BIG THANKS
Does it come in metallic blue?
DBMW is offline   Reply With Quote
