Old 12-11-2010, 11:16 PM   #1
s2keric
My Ride: 2003 325i
Drive shaft
Just picked up the car and was told it needed new U joint which entails replacing the driveshaft... and from what I have searched seems to agree.
The car has a slight vibration on acceleration, and right before i bought it the car received a new carrier bearing and guibo. So.. now this is my problem what is a recommended company to buy a new drive shaft from? I found Driveshaft Specialist but, since I am new to BMW's I wanted to see what you guys recommend. Also how easy of a remove and replace is this or would I be better off taking it somewhere?
http://www.driveshaftspecialist.com/...0html/BMW.html
2003 325i - Daily
2002 S2000 ASM Mugen Volk Racing Tein Voltex- Weekend
s2keric is offline   Reply With Quote
Old 12-12-2010, 08:31 AM   #2
McSpeed
My Ride: 2005 ZHP TT Stg 1
I don't think people like the DSS custom made drive shafts but I imagine their rebuilds are ok. Take the driveshaft off is pretty staright forward. It's just exhaust -> heatshield -> driveshaft. Detachment may be confusing at the diff end where it has slots for prying with a screwdriver. This DIY covers that part: http://www.bokchoys.com/differential/diy_diff.htm
If they put the CSB on, when you reinstall you'll just need torque specs and instructions for setting the CSB preload.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 12-12-2010, 10:48 AM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
Having done some research on driveshafts recently, I found that BimmerWorld sells rebuilt drive shafts. They're a trusted forum sponsor and if anyone knows how to rebuild a BMW driveshaft, it would be BW.
http://store.bimmerworld.com/remanuf...shaft-p64.aspx
Swapping the driveshaft is pretty straightforward if you're comfortable working on cars.
Old 12-12-2010, 01:13 PM   #4
s2keric
My Ride: 2003 325i
Thanks for the info if Bimmer world is the more reliable for parts id rather go with them. I am fairly comfortable working on cars so this shouldn't be a problem
2003 325i - Daily
Old 01-13-2012, 12:01 PM   #5
daz415
My Ride: BMW 330i
Send a message via MSN to daz415
Just searched the forum for the torque specs on the driveshaft reinstall and couldn't find them. anyone know it off hand? Thanks dudes and peace out...
daz415 is offline   Reply With Quote
