Old 05-04-2017, 10:41 PM   #1
jeffbert
My Ride: 03 325Ci Convertible
flashing red oil when slowing down
Hi all,
Got a red flashing oil light when ever I get my 2003 325ci to normal running temperature once I slow down to below 10mph. As soon as I start to speed up, even every so slightly, it goes away (most of the time)... always goes away once I get past 10mph. Usually goes away if i turn car off and back on. Never comes on when I'm at faster speed than say 10mph, only comes on when I slow down.
Is this indicative of a bad oil level sensor? Bad oil pump? Serious issue?
Thanks,
Jeff
jeffbert is offline   Reply With Quote
Old 05-05-2017, 07:45 AM   #2
markusmarkus
My Ride: 2001 330Ci
Did you check the oil level? How many miles on the oil and filter? Are you hearing any knocking when the red oil pressure warning light is on?
It's not a leak. It's one of 3 things:
- the oil pressure sensor is bad
- the oil pump is going bad
- there's a blockage in the oil path so that the oil pressure sensor sees a reduced pressure.
The sensor is located on the oil filter housing. The dipstick is nearby.
Old 05-05-2017, 08:44 AM   #3
jeffbert
Oops, should have added those details:
185k miles
Oil level in spec
No knocking or other weird noises
Thanks for reply. Going to start with Oil Pressure Sensor.
Old 05-05-2017, 04:34 PM   #4
jeffbert
Linking in thread to fix Oil Pressure Sensor: http://forum.e46fanatics.com/showthread.php?t=709214
Old 05-05-2017, 04:46 PM   #5
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
I would be changing the OPS immediately. Cause if it's not that then you have a serious potential to kill the engine through oil starvation. Perhaps the pump is failing or there is a clog but in any case if it is not merely a sensor error then I woulds't be driving the car.
BMW-North is offline   Reply With Quote
