Old 12-12-2010, 09:14 PM   #1
mhagley323
My Ride: 330i
Turn Signal Coding
Has anyone coded there Turn signal to blink three times with one click similar to the newer cars.
03' 330i
Mods
|M Tech II|P46| Orion V2|Painted Rear Diffuser and Moldings|Clears|Painted Grills|Koni FSD|Eibach|M6|WeissLicht LED|
09' ///M5
Mods
|BMW Performance Gloss Grills, Gills and Reflectors|SuperSprint|RPI|WeissLicht LED|
mhagley323 is offline   Reply With Quote
Old 12-13-2010, 04:02 PM   #2
mhagley323
My Ride: 330i
No one?
03' 330i
Mods
09' ///M5
Mods
Old 12-13-2010, 10:38 PM   #3
xdmikey
My Ride: e46 cabrio
i like the 3shotburst myself!
i think it has something to do w/the main control module because i set them on my wife's x5 by pushing on the "obc" stick.
DINAN CAI, 3.46 DIFF, CDV DELETE,DINAN S2 & EXHAUST,HARDTOP,f/14 wheels(gone, back to 68s and quickness!)
xdmikey is offline   Reply With Quote
Old 12-14-2010, 07:04 PM   #4
mhagley323
My Ride: 330i
some cars have the option of turning them on and off but i've only seen it in the iDrive system
03' 330i
Mods
09' ///M5
Mods
Old 12-14-2010, 07:42 PM   #5
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
you can change it via NCS Expert/SSS if i'm not mistaken. Like you said, you have to have a new module.
SL Blak Soldier is offline   Reply With Quote
Old 12-14-2010, 07:45 PM   #6
Mouf
My Ride: 2004 ZHP Sedan
It is changed via the Car Key Memory. It needs to performed by the dealer with the SSS or ISSS.
Sent from my Droid using BimmerApp
Mouf is offline   Reply With Quote
Old 12-14-2010, 09:23 PM   #7
Locutus09
My Ride: Something Slow
IIRC, you need to have a 2005+ LCM in order for it to code properly. I know of 1 ZHP that was able to do it
Locutus09 is offline   Reply With Quote
Old 12-15-2010, 07:43 AM   #8
theinfamousdrew
My Ride: 911 Turbo / E70
+1 on needing a newer LSZ module
once i build a new one ill hook it up to your car and take a look
theinfamousdrew is offline   Reply With Quote
Old 12-16-2010, 12:58 AM   #9
mhagley323
My Ride: 330i
My man, thanks, give me a shout when things look good your way!
03' 330i
Mods
09' ///M5
Mods
Old 12-16-2010, 03:54 AM   #10
TerraPhantm
My Ride: M3 & ZHP
You need a 2006 or newer LSZ. I've got this function on my car, but I grabbed an LSZ from an 06 M3 and wiped the VIN so that I can use it.
Old 12-16-2010, 10:49 AM   #11
mhagley323
My Ride: 330i
That's what I need but I didn't think it had to be 06+. I thought it could be coded as a euro-spec e46 etc...
Im trying to learn the coding capabilities still..
03' 330i
Mods
09' ///M5
Mods
Old 12-18-2010, 03:01 PM   #12
TerraPhantm
My Ride: M3 & ZHP
The car can be any year, but the module has to be from on 06. Basically you need a c36 or c37 LSZ to get it to work. I think it should be possible to upgrade the software through some hardware hacking, but thats beyond my capabilities.
Old 12-18-2010, 05:56 PM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Meh, I think it's stupid.
Old 12-18-2010, 05:59 PM   #14
TerraPhantm
My Ride: M3 & ZHP
IMO it's nice for lane changes. More useful than just a single flash
Old 12-18-2010, 06:08 PM   #15
Mouf
I would not recommend a newer LCM. The LCM is one of two modules that stores the VIN/mileage.
Sent from my Droid using Bimmer App
Old 12-18-2010, 06:31 PM   #16
TerraPhantm
My Ride: M3 & ZHP
With the right tools the LSZ can be reset to factory settings, and then resynced with the car it's going into. Or you can just buy a brand new one.
Old 12-18-2010, 07:00 PM   #17
04yfz
My Ride: A car
How were you able to wipe the VIN? I've been wanting 3 flash for a while, I loved it on my e90.
Detailed Image Auto Detailing Supplies
[/CENTER]
04yfz is offline   Reply With Quote
Old 12-18-2010, 07:10 PM   #18
mhagley323
My Ride: 330i
3 flash is huge to me. I like when im driving the m5 i can just tap it.
03' 330i
Mods
09' ///M5
Mods
Old 12-18-2010, 07:27 PM   #19
TerraPhantm
My Ride: M3 & ZHP
I have a tool (PASoft 1.4) that can be used to wipe the VIN and mileage off an LCM
Old 12-19-2010, 02:44 PM   #20
04yfz
My Ride: A car
So once you do that, if you program your cars vin and actual mileage, there will be no tamper dot?
[/CENTER]
