E46 Xi Forum
Old 12-13-2010, 10:41 PM   #1
TX_Bullet
My Ride: 2001 325Xi
Inner ball joint removal help
Well this job was more difficult than I thought. I took the nut of and smacked the side quite a bit hoping for it to pop out.
I have to wonder if its pressed and/or I have to remove the control arm just to replace the inner ball joint.
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 12-14-2010, 05:56 AM   #2
lotar_6
My Ride: '01 xi, '94 Rado
I've not done this job yet, but maybe try a ball joint separator tool? Or maybe a pickle fork?
if all else fails... a BFH
lotar_6 is offline   Reply With Quote
Old 12-14-2010, 08:01 AM   #3
Kubica
My Ride: 2003 325xi
Can you remove the two bolts holding it to the subframe?
Old 12-14-2010, 08:57 AM   #4
TX_Bullet
My Ride: 2001 325Xi
Easily......I'm thinking a gear puller may help push it off. Pickle fork wont work
I'm assuming you just draw it through the control arm when putting it back together
The Mods
Power Flex FCAB
Old 12-14-2010, 10:59 AM   #5
Kubica
My Ride: 2003 325xi
I think you should be able to use a prybar to get it out once the two bolts holding it to the subframe and one nut holding it to the control arm are off.
If that doesn't work, disconnect the FCAB carrier from the subframe too and that should give you room.
Old 12-14-2010, 07:23 PM   #6
TX_Bullet
My Ride: 2001 325Xi
Lucky for me I have powerflex fcabs so the CA will just pull out. I'm also thinking the 175k on my car isn't helping
The Mods
Power Flex FCAB
Old 12-14-2010, 08:24 PM   #7
TiAgXi
My Ride: e46xi, e46m
125k miles here and to get my outer joints off I used a pickle fork. I had to hammer the crap out of it to make it work though.
TiAgXi is offline   Reply With Quote
Old 12-14-2010, 08:43 PM   #8
athayer187
My Ride: 2004 330xi
I'd use one of the screw type separators - they're the most efficient when there's clearance and also would not subject the other ball joint to any harsh loading. Additionally, make sure that the ball joint mounting points are clear of the subframe, one side uses a sleeve to help center the holes to the subframe. This may be constraining the ball joint as you're trying to hammer it out.
1988 535is - 10.5:1, PB N31 cammed M30B35, Miller WAR and MAF, style 29's and style 5's, urethane everywhere, revalved Bilsteins
500/450 Coilovers, Vorshlag camber plates, UUC SSK, Mason Eng. strut bars
Hella H1/H4's, Schroth Rallye 3's, Dinan 25/19 sways, e32 750i brakes, Bav Auto headers, M5 clutch and FW
athayer187 is offline   Reply With Quote
Old 12-14-2010, 09:27 PM   #9
TX_Bullet
My Ride: 2001 325Xi
I actually came across a tie rod seperator tool when I was returning the pickle fork which seems to work WAYYYYY better. I will attack the ball joint again tomorrow when I have time but I feel confident the tie rod tool will do the trick.
The Mods
Power Flex FCAB
Old 12-14-2010, 10:51 PM   #10
TX_Bullet
My Ride: 2001 325Xi
this is the tool
http://www.autozone.com/autozone/acc...uller/_/N-264w
the third one down
The Mods
Power Flex FCAB
Old 12-15-2010, 10:15 PM   #11
TX_Bullet
My Ride: 2001 325Xi
success!!!! worked like a charm. Took about 45 minutes to swap out
The Mods
Power Flex FCAB
Old 12-15-2010, 11:20 PM   #12
lotar_6
score!
