Old 04-29-2003, 09:39 PM   #1
showoffcafe
My Ride: 2000 323 CI
m3 mirror install help.
Hey guys,
I am trying to install M3 mirrors from a 2003 M3 into a 2000 323Ci. I see 9 wires and was told that the 2k only has 6. Is this correct? These didn't come with the switch so I need to cut and rewire.
Thanks!
Daniel Nguyen
and yes I did search.
showoffcafe is offline   Reply With Quote
Old 04-30-2003, 10:08 AM   #2
johndddd
My Ride: 02 m-3
match up color for color see DIY install m-3 mirrors in tech.
johndddd is offline   Reply With Quote
Old 04-30-2003, 10:13 AM   #3
showoffcafe
I did just that. The problem is that my old mirrors had one extra black wire than the M3 mirrors and now my memory on the right side does not work and when I put the car in reverse it tilts up but never goes down.
Old 04-30-2003, 10:19 AM   #4
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
showoffcafe, I think you have the install pretty much like the one in the DIY section of this site. Its pretty well documented that you loose memory function as well as backup tilt function because of the different wiring. Otherwise you would need to change the harness inside your car to 2002 wiring harness.
Mr.Motorwerk
MrMotorwerk is offline   Reply With Quote
Old 04-30-2003, 11:08 AM   #5
showoffcafe
Its wierd though. The memory works on my left side mirror and the tilt worked on the right it just never comes back up.
Old 05-06-2003, 12:49 PM   #6
showoffcafe
How hard is it for you to swap out the old motor and wiring harness to put it into a m3 mirror? Would you have to get a new glass piece?? Help!
Old 05-06-2003, 07:43 PM   #7
showoffcafe
dang people. anyone? the dealership is stuck as well. i will choke someone at pacific bmw for sending me the wrong ones.
