E46 Xi Forum
Old 12-15-2010, 10:29 PM   #1
pcdsl
My Ride: 2002 330xi (SOLD)
Strange Scrapping Sound (front driver side)
Hey guys, I have this strange scrapping noise that only happens when I drive the car in the morning. It's either rotational or maybe even when the suspension moves. I'm not too sure how to diagnose it. I have recently replaced both front axles and I thought the noise went away but now it's back. I guess it could be axle related, but I don't know why these new remanufactured ones would go bad so quickly. Any thoughts? It doesn't come back after driving for awhile (10min). It pretty much goes away all day, and I think when I'm turning left or right it doesn't make that noise. I also thought it might be my suspension going bad... so lost. Thanks for any help!
2002 330XI
pcdsl is offline   Reply With Quote
Old 12-16-2010, 02:17 AM   #2
TwoDuckDad
My Ride: 2001 330xi jet black
the protective plastic shield under the engine (aft piece) is very close to the axle boots. Check to see it is clear of the boots.
Premium, Sport, & Cold Weather Packages
If you dog doesn't like somebody maybe you shouldn't either.
TwoDuckDad is offline   Reply With Quote
Old 12-16-2010, 11:20 AM   #3
Rickna
My Ride: '01 330xi - '09 IS-F
For whatever reasons, the dust shield behind the hub was bent and rubbing on the hub. I had to pry it away from the back of the hub.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 12-16-2010, 04:36 PM   #4
KROMExi
My Ride: 02 330xi
same problem (exactly at 40 mph) my mechanic said wheel bearing everybody here will blast you axle choice
KROMExi is offline   Reply With Quote
Old 12-16-2010, 04:44 PM   #5
andertrack
My Ride: 2003 325xi
I am having the exact same thing. Sometimes it happens when I go over bumps or accelerate, and other times it just happens for no reason at all. I recently got my car with 80k on it and the mechanic who looked at it said everything was fine, but this noise is really bothering me.
andertrack is offline   Reply With Quote
Old 12-16-2010, 05:10 PM   #6
Kubica
My Ride: 2003 325xi
2002 330XI
I know the sound you mean- it's just the brake pad (or rear brake shoe) rubbing slightly on the rotor. It goes away after you use the brakes a few times or get up to speed.
DON'T WORRY ABOUT IT!
A1 cardone reman axles are a tried-and-true axle replacement. Nobody has reported any problems with them.
Old 12-17-2010, 04:46 PM   #7
e36-2.0
My Ride: 330xi
if its the brakes get a brake fluid flush and/or you might need new caliper piston seals.... axles wont ever make scraping sounds op claims to have
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 12-17-2010, 05:30 PM   #8
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Does it sound like this?
If so, it could be the dust shield.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 12-19-2010, 01:09 AM   #9
pcdsl
Thanks for the suggestions guys, I'll check out the front brakes and the rear shock mounts. \
@Kevin: no it doesn't really sound like that... maybe it could be my struts going bad, I have Bilstein Sports.
Old 12-19-2010, 11:50 AM   #10
Rickna
Thia's what it was for me.
2001 BMW 330xi
2009 Lexus IS-F
Old 12-20-2010, 03:38 PM   #11
VMRWheels
VMRWheels's Avatar
It's a pretty common issue. When I was lowering my car I had put a jack around that area and when the hub was resting on it it must have bent it slightly.
Old 12-20-2010, 06:36 PM   #12
pcdsl
hmm I will double check mine. Thanks!
Old 12-20-2010, 10:23 PM   #13
Rickna
Been there, done close to that.
2001 BMW 330xi
2009 Lexus IS-F
