Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 10-14-2012, 07:57 PM   #21
Mflara20
My Ride: 04 330i
I have to replace my Automatic transmission thermostat on mine and it fix my leak. Hope this help someone
Mflara20 is offline   Reply With Quote
Old 10-14-2012, 08:59 PM   #22
BM-MAN
My Ride: Hot 3 coupe
Send a message via MSN to BM-MAN
For some reason, I think the ET bracket had an o-ring on the smaller port that fits into the ET.
But, BM, if you just did the radiator, the other possibility is that you either got the radiator for the wrong car (manny and auto rads. are different if you got the Behr)...or if you got OE radiator, then there's a leveling screw that changes it for manny/auto.
There've been a number of posts where the leak comes down where you're seeing it (sort of)...and it's from the radiator itself.
HTH...don't hate me! I'm just a messenger!
Thank again D. The rad is BEHR and I quadruple checked it was the correct auto rad for my car.. Even when looking under car and can see the leak coming off the tran cooler but can't tell since the trans cooler is in the way. BTW it only leaks when the ET tank is full and I've been driving car for a good 30min trip. I'm hoping someone can chime on on this O-ring issue. I have a strange feeling its coming from there. BTW I did install a new Tranny T-Stat.
BM-MAN is offline   Reply With Quote
Old 11-10-2012, 06:13 AM   #23
daki_bmw
My Ride: 330Ci
I've got brand new ET right here with me, and I can se o-rings in the bigger AND smaller hole. Since it is not aftermarket ET, I presume that's the way it should be. I know it's kind of an old thread, but maybe it will help someone.
daki_bmw is offline   Reply With Quote
Old 11-10-2012, 06:18 AM   #24
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You ever find that leak, bm-man? It really did sound like the common 'wrong radiator' leak...I know it's a pain to deal with stuff like that.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-14-2016, 02:03 AM   #25
braytonwright
My Ride: 2000 BMW 323ci e46
Expansion tank leak
My expansion tank did the same thing. Couldn't get it to stop leaking from the bottom fittings. I have the aluminum mishimo (or however its spelled tank) but you still have to use the stock plastic drain plug fitting for the bottom. I couldn't get it to seat right, making sure the clip was in correctly.
Start by using VASOLINE, it will be your best friend with all the hose fittings. Lube up the gaskets, inner hose, the fitting it goes on, AND the clips to make sure they slide into position correctly.
That wasn't enough in my case though. I added another rubber gasket over the fitting to go into the expansion tank. It has to be small enough in circumstance to fit over the the hose fitting and slide into the tank, but I used a wider one and it stopped the leaking and the wobble. Boom, no more leak even if tug on it.
Even though the mishimo expension tank uses the stock bottom fitting I would still recommend it. The stock expansion tanks is probably the weakest point in these vehicles. It a good $200 dollar investment
braytonwright is offline   Reply With Quote
Old 11-14-2016, 02:08 AM   #26
braytonwright
I'm also having the radiator leak do to it being compatible with automatic BMWs. I did a high pressure coolant flush with a garden hose so I think I lost the plug during that. I've got it rigged up right now not sure if its going to work yet but if not I'll probably just pick up the plug from a dealership.
