General Off-Topic
Everything not about BMWs. Posts must be "primetime" safe and in good taste. You must be logged in to see sub-forums. Click here to browse all new posts. |
#1 |
Garage Lifts
Guys,
I am looking for a lift for one of my stalls. I want to store my E30 and Datsun in the same spot. Need it both for storage and under carriage access to work on them both. I will be driving in and out so it needs to be practical and provide plenty of clearance. I have seen the pictures in the ultimate garage build threads but they don't discuss 2 post vs 4 post benefits. What have you done, what works the best? Thanks, Tim |
#2 |
seems like 4 is safer but for either one you'll need a good foundation |
#3 |
Yeah, that's ugly. 4 post seems better for sure. The backyard buddy offerings do not even have to be bolted to the floor.
Anyone have experience with them? |
#4 |
i see a lot of ppl using them. they seem very safe based on the wide column base
#5 |
Past Site Sponsor
My Ride: W/E I have in stock
4 post doesnt let you work on the brakes/suspension/bushings. you would need to get another jack to lift the wheels. It does let you work under the car for oil changes/trans work/exhaust work.
2 post...yeah ive seen them fail but i would think its RARE. You have to get a 2 post professionally installed, you dont need an install on a 4 post I use a mid rise lift at my shop. I dont spend a lot of time under it and it was only $500 (used, $2500 new). Pro: its easy, quick and simple 110v. Con: hard to access transmission and only goes about 4' high. Pic: Last edited by Starfire Auto; 12-19-2010 at 04:10 PM. |
#6 |
Registered OG User
I would imagine you need substantial clearance on either side for a 2/4 post. I don't know if you have a 3 car garage and you want to use the middle one or something smaller?
Whatever you do, take your time, do your research and get some pros to do the job. I can't imagine anything more dangerous at home than a falling car.
#7 | |
Are 2 posts really designed for long term storage of a vehicle? Seems like they are made for working on a car but not holding one in the air for months at a time. What do you think? |
#8 |
2 post.
You can't work on suspension with a 4 post.
![]() TC Kline | BMW Performance | Active Autowerke . |
#9 |
Can you imagine the phone call to the owner of the van ?
Good afternoon Mr. Smith, uhhhhhhhhh, we had a little problem with your van today.... It is not going to be ready when we promised this afternoon. Allow me to explain why, better yet.....I'll let you speak to my supervisor.
"The grand essentials to happiness in this life are something to do, someone to love, and something to hope for."....Joseph Addison
#10 |
#11 |
I don't see why not. The lift locks when its up.
#12 |
^^ this. As long as it's sitting on the locks I dont see a problem. Now, what happens if you store it for the Winter and when you go to lower it in the Spring the hydraulics are messed up? Like if one of the pistons was leaking.
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes Coming Soon: Open to suggestions ![]() Last edited by grkm3; 12-19-2010 at 07:18 PM. |
#13 | |
And also I read one of the guys said 4 post is safer, despite what you may think, 2post are much safer and have a higher load rating.
#14 |
Finally breaking ground on Tues, turning my 3 stall into a five stall...now I will have plenty of room for a lift.
Any new thoughts on the best way to go? |
#15 | |
Sounds like a four post for storage and non-suspension work, with a midlift tucked away for anything else.
#16 |
I think that one is all that I will do
#17 |
ILCUTAWOOTIE
check costco.com
#18 |
my dad has a 2 post lift in his garage. every winter we store a car on it for 3-4 months straight. never have had a problem doing this
#19 |
You can work on suspension with a 4 poster, Most of them have rails with 2 air powered jacks one in the front and one in the pack so you can lift the wheels off the ground, Most tire change places use them and the work fine and also have locking systems
Winter Authority When Hell freezes over,we'll play Hockey there too
![]() Its fundamental to our nature, man must explore. you've Met a terrible fate haven't you ? KONI /Michelin/Stoptec/ Bimmerbrake / MTechII/AA Stage one (for now) Questions about Header wrap? clickHere Supercharger build thread click Here Last edited by E46330iguy; 05-12-2012 at 12:45 AM. |
#20 |
Modded ///Member
2 post will be fine. Only way I see a 2 post failing is by leaving a full sized truck or suv on it for long periods at a time.
![]() ** Too much for a signature ** Instagram @ j_cerna |
