Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 12-20-2010, 08:27 AM   #1
adrianpl
My Ride: 01 330ci
Sensitive steering
My steering is very sensitive. If the highway is on a angle just a bit the car will start pulling towards one side. If their are bumps in the road, everything is felt in the steering. I also get a knocking sound when going over bumps. My thought is something is wrong with the steering. Steering rack? Also i get a little bit of vibration on the highway at some speeds.
I have changed the following:
Control Arms and bushings
Tie rods
Sway bar endlings
steering wheel coupling
Also put on new tires and alignment
Running currently on stock suspension for the winter
adrianpl is offline   Reply With Quote
Old 12-20-2010, 02:01 PM   #2
adrianpl
My Ride: 01 330ci
bump
Old 12-21-2010, 02:22 PM   #3
adrianpl
My Ride: 01 330ci
anyone?
Old 12-21-2010, 08:55 PM   #4
eweis
My Ride: 1999 328i
First thing I think of is the CABs, but since you've already chgd those, I'd reinspect them because if you install them wrong they can fail prematurely.
You sure its coming from the from?
Sent from my HERO200 using BimmerApp
eweis is offline   Reply With Quote
Old 12-21-2010, 10:33 PM   #5
Steven747
My Ride: 05 330ci
try exhaust hangers? they tend to rattle at variant highway speeds and could be caused by the sudden up and down from a bump.. not to sure about it leaning but... lmk
Old 12-22-2010, 08:50 AM   #6
TxZHP04
My Ride: ESS TS2+ ZHP
What brand parts were used to replace the items listed above? Also, try re-torquing the sway bar end links. They can cause a knocking/bumping noise if they are loose, even if they don't seem to be loose (been there, had that problem). Can you post your most recent alignment specs?
Old 12-22-2010, 12:02 PM   #7
trippmann
My Ride: 2000 323i
Send a message via AIM to trippmann
this^
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 12-22-2010, 12:50 PM   #8
franz
My Ride: 03 330i
I felt that way until I removed some of the toe that was in spec. I prefer less front toe, a lot less twitchy. As for the clunk double check inner and outer sway links and bushings.
franz is offline   Reply With Quote
