Fan clutch removal without tools? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-20-2010, 10:30 AM   #1
Alexotronic
Alexotronic's Avatar
My Ride: 2001 330Ci
Has anyone here been able to do this without that skinny 35mm wrench and nut holders?
Alexotronic is offline   Reply With Quote
Old 12-20-2010, 10:33 AM   #2
nathancarter
My Ride: 02 330i
You can probably do it with a standard (not skinny) 32mm wrench and no counter-holder, if you're resourceful and lucky.
Without that wrench, though, it's close to impossible. MAAAAYYYBE a crescent wrench might work?
Originally Posted by GoingNuts View Post
You are incorrectly.
I don't need evidence, I just know.
nathancarter is offline   Reply With Quote
Old 12-20-2010, 11:17 AM   #3
seanm330
My Ride: 03' 330CI
Super simple just use an airhammer with a long blunt bit. Hit the edge of a corner on the fan nut. just takes a tap to break it loose, then spin it off by hand. Remember its left-hand threaded!!
seanm330 is offline   Reply With Quote
Old 12-20-2010, 11:18 AM   #4
shanneba
My Ride: 2003 330Ci
I was able to remove mine with a standard Craftsman 32mm wrench without the pulley holder.
It had been removed once before by the dealer about 3 years ago, that may have helped.
Join BMWCCA
Old 12-20-2010, 11:25 AM   #5
san_siro
My Ride: 323i
I also was able to just use the 32 mm Craftsman wrench to loosen it and it unthreaded off pretty easily.
I had the W/P bolt holding tool also but couldn't get the correct angle to use it. Anyways, if the clutch has been taken off before then you probably can just
get by using the 32 mm wrench.
san_siro is offline   Reply With Quote
Old 12-20-2010, 11:34 AM   #6
jdstrickland
My Ride: '94 325iC & '00 323i
I took mine off with Channel Locks. The nut is not supposed to be _really_ tight. It is a Reverse Thread that is made tight by the rotation of the engine instead of being made loose.
Old 12-20-2010, 12:04 PM   #7
Alexotronic
My Ride: 2001 330Ci
Awesome, thanks for all the info!!!
Old 12-20-2010, 12:23 PM   #8
jdstrickland
You might have to use a screwdriver (a very long one) wedged across two of the four screws that hold the pulley onto the front of the water pump to stop the pulley from turning while you turn the nut on the fan clutch. The torque on the nut is measured in inch pounds, or very low foot pounds.
Old 12-20-2010, 12:58 PM   #9
seanm330
My Ride: 03' 330CI
The torque spec for it is 40Nm or 29.5 FtLbs (354 InLbs) That really isnt that tight, if you can stop the pulley from turning it should be fairly simple to loosen it unless someone has cranked it down super tight before.
