Thinking about replacing all this. Any suggestions? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 12-21-2010, 11:59 AM   #1
AnRman
My Ride: 2002 330I
I picked up an 02 330i with 105K miles. I'm experiencing some moaning and creaking in the front end and am thinking that I should just replace all of this now. I'm interested in maintaining a fairly comfortable ride but not loosing the sport feeling of the car. I have been in trucks and SUVs for the last 15 years and am out of the loop on a lot of this stuff. I am interested in hearing what else, if anything, I should be looking at in regards to this endeavor.
1 - left front control arm - ZHP - 31122282121
1 - right front control arm - ZHP - 3112228212
2 - locking nuts - 32216769539
4 - locking nuts - 31106774714
1 - left front sport shock - 31312282459
1 - right front sport shock - 31312282460
2 - front bump stops - 31306757046
6 - locking nuts - 31316769731
1 - front sway bar - 23.5mm - 31356757168
2 - sway bar bushings - 23.5mm - 33556751269
2 - hex nuts - 33306760587
8 - locking collar nuts - 07119904295
2 - rear sport shocks - 33522282461
2 - rear shock bump stop - 33506757047
2 - locking nut - 33521137360
3 Series Repair Shop Rear Shock Tower Mounts (Pair)
Z4 Control Arm Bushing Kit
AnRman is offline   Reply With Quote
Old 12-21-2010, 12:35 PM   #2
Grande D
My Ride: E36 M3
I would get Koni Yellow shocks/struts as opposed to OEM shocks, they don't last long and Konis ride better. Also do your rear shock mounts with reinforcement plates when doing the shocks.
Old 12-21-2010, 12:47 PM   #3
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
M3 Vert rear shock mounts with Z3 reinforcement plates, if you want a solid rear setup.
I 2nd the Koni's instead of OEM shocks.
Changing out the front swaybar is probably overkill, just change the endlinks.
And finally, do your rear trailing arm bushings.
-Brendan
Sponsored Links
Advertisement
Old 12-21-2010, 02:55 PM   #4
AnRman
My Ride: 2002 330I
Most of this is in a package from Turner. Trying to make this as simple, stupid as possible...with good results of course. I'm fairly convinced that all this is original on the car, so if I can get another 60K to 100K out of these, I would be happy.
Old 12-21-2010, 03:17 PM   #5
Levi@AvTechParts
Past Site Sponsor
My Ride: e46 sedan
I just got some stainless steel shock tower reinforcement plates today. They're basically the same thing as z3 plates. PM me if you're interested.
Levi@AvTechParts is offline   Reply With Quote
Old 12-21-2010, 06:46 PM   #6
McSpeed
My Ride: 2005 ZHP TT Stg 1
Originally Posted by Levi@AvTechParts View Post
Available soon: SS shock tower reinforcement plates w/oem gaskets *All e30/z3/e36/e46 including vert.*http://i277.photobucket.com/albums/k...-41-57_595.jpg
Hi Levi- are the gaskets included *under the assumption* it's a good idea to replace them whenever RSMs are unbolted (the gaskets between the RSM and the car metal)? Or are the ones you include to be used between the reinforcement plate and the car metal?
EDIT: *
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 12-21-2010, 06:52 PM   #7
Levi@AvTechParts
Past Site Sponsor
My Ride: e46 sedan
Originally Posted by McSpeed View Post
Hi Levi- are the gaskets included because it's a good idea to replace them whenever RSMs are unbolted (the gaskets between the RSM and the car metal)? Or are the ones you include to be used between the reinforcement plate and the car metal?
Yes, they are included. They're the same ones used to between the shock mount and shock tower (under shock tower). I was selling them with the plates because I read about some guy's reinforcement plates made a squeaking sound and the gaskets fixed it. For an extra dollar, I'd include another set of gaskets.
Old 12-21-2010, 07:29 PM   #8
McSpeed
So, to clarify, yours are included for antisqueak action between the reinforcements and the car metal- gotcha
Old 12-21-2010, 07:40 PM   #9
Levi@AvTechParts
Past Site Sponsor
My Ride: e46 sedan
Yeah but I don't even know if it's worth putting them under the plates. I've never noticed squeaking and nobody else sells gaskets with the plates. I'll still include them. If there would be squeaking, put them under the plates. If there's no squeaking, just save them and you have an extra set so you can replace the old ones under the shock tower when needed.
Old 12-21-2010, 07:47 PM   #10
WALKD U
My Ride: Just Fast!
It is not...Reason, I deleted my other post didn't want to be a Dick. If they are on tight. They wont move. No Movement = No Squeaking...Everything on the car is metal on metal...
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 12-21-2010, 07:51 PM   #11
Grande D
My Ride: E36 M3
I use gaskets on top and on the bottom; the reinforcement plates make metal on metal contact. I'd like to preserve some level of finish/protection on the tower itself.
Old 12-21-2010, 07:52 PM   #12
Levi@AvTechParts
Past Site Sponsor
My Ride: e46 sedan
-TrippinBimmer
I agree with you TrippinBimmer. I'll go edit the sale post because it doesn't make sense having them under the reinforcement plate.
Old 12-21-2010, 07:59 PM   #13
WALKD U
My Ride: Just Fast!
It wont mess up the finish if installed correctly...
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
