E46 Xi Forum
Old 12-20-2010, 04:54 PM   #1
septalrage
My Ride: 2004 325xi
Most stock like ride
From reading many previous posts, it seems that the consensus for the most comfortable ride with aftermarket suspension systems is Eibach pro kit springs with Koni shocks? Dinan no longer makes suspension system for E46 XIs. Any other contenders?
septalrage is offline   Reply With Quote
Old 12-20-2010, 07:01 PM   #2
Kubica
My Ride: 2003 325xi
Yes that's the softest aftermarket combo.
There aren't many choices- HnR or Eibach for springs, Koni or Bilstein (HD or sport) for shocks.
Of course you can always get OEM Sachs shocks and OE springs, or coilovers.
If your shocks are blown, but springs are still good, Bilstein HDs give a slightly firmer/sportier ride than OEM.
Old 12-22-2010, 10:24 PM   #3
Rickna
My Ride: '01 330xi - '09 IS-F
Im using Eibach Pro springs (about 1" drop) with Koni adjustable shocks for around 5 months. It's the closest you can get to stock ride.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 12-22-2010, 11:16 PM   #4
septalrage
My Ride: 2004 325xi
Where did you buy eibach springs and Koni shocks? I looked at Shox.com but their website made me nervous with misspelled words. Not sure I would get the right parts.
Old 12-23-2010, 07:16 AM   #5
Rickna
Shocks I got directly from Koni website-they were running a special. Eibach springs I got from TireRack.com.
2001 BMW 330xi
2009 Lexus IS-F
Old 12-23-2010, 12:23 PM   #6
Dreamliner330
My Ride: 330xi
I've been very happy with my Koni/Eibach setup. I have my Konis set to the softest setting and I am happy.
I got my Konis from: www.ajusa.com
I got my Eibachs from: www.*************er.com
My total for the springs and shocks including shipping: $873.40
I also bought the rear reinforcement plate from Turner for: 39.96 http://www.turnermotorsport.com/html..._ID=TSU9975100
Also, I plan on having my car for a long time, so I ordered all the wearable suspension components from Tischer:
Originally Posted by Dreamliner330 View Post
I just replaced my suspension, the comprehensive way, and here is the order list:
OEM BMW Parts:
07119900402, 33521136283, 33531094518, 33531136385, 33526772864, 33531136395, 33521092362, 31356778832, 31336752735, 31331091867, 31331096664, 31311139453, 31336752832, 31316769731
2x of each, and 6x of the last part (strut nuts).
Vendor Website
Eibach:
2089.140
Vendor Website
Koni:
8741-1481RSPORT
8741-1481LSPORT
8040-1343SPORT
Vendor Website
There is all the part numbers and links for all the shocks, springs, bearings, strut mounts, spring pads, shock bumpers, dust covers, bolts and replacement strut nuts you will need for a comprehensive suspension replacement.
My total parts cost: $1160.47.
I spent a total of $1200.43 for the suspension and all the wearable components. What I did is the most comprehensive way to replace your XI's suspension.
Being in Minnesota, I STRONGLY recommend you use IMOLA MOTORSPORTS, they charged $450 for the suspension swap.
Dreamliner330 is offline   Reply With Quote
Old 12-23-2010, 12:56 PM   #7
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Koni FSD do ride very well
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 12-23-2010, 02:50 PM   #8
Dreamliner330
My Ride: 330xi
I don't think there is a FSD solution for xi's.
Old 12-23-2010, 05:43 PM   #9
septalrage
My Ride: 2004 325xi
Wonder if I need to replace my wearable suspension parts on 04 XI with 56K miles if gonna install Eibach and Konis. Any thoughts?
Old 12-23-2010, 08:15 PM   #10
hammerheart
My Ride: 02 330XI
I bought my set from Tirerack. The shipping was very fast.
Avoid Autoanything. Their website says they have koni rear in stock but actually they don't. Wasted me 3 weeks.
hammerheart is offline   Reply With Quote
Old 12-23-2010, 11:59 PM   #11
Dreamliner330
My Ride: 330xi
You don't have to replace any of the extra parts in the list...but they are called wearable for a reason.
The cost of labor alone to replace one of those items after-the-fact is more than buying all the parts right away.
Old 12-24-2010, 01:53 PM   #12
Levim9
My Ride: S54 325i & LSB M3
The rear reinforcement plates were mentioned above. Check the link in my signature. $28 shipped a set
Look into getting front strut tower reinforcement plates too. They're cheap and so much less of a hassle when you put them in while doing suspension work. They're good to have so you don't have to ever worry about mushrooming strut towers or shock tower failure.
Might be a good deal if you order these two together.
BMW front plates - http://www.turnermotorsport.com/html...ID=51717036781
TMS rear plates- http://www.turnermotorsport.com/html..._ID=TSU9975100
Levim9 is offline   Reply With Quote
Old 12-24-2010, 03:06 PM   #13
septalrage
My Ride: 2004 325xi
For those who have bought them, are the TMS rear plates priced per pair?
Old 12-24-2010, 03:07 PM   #14
Levim9
Yes, they come as a set.
Old 12-24-2010, 03:17 PM   #15
septalrage
My Ride: 2004 325xi
Koni FSD available for 325/330XI now. Here's the link http://bit.ly/i0e7Bi Anyone have experience with these? Shocks should affect drop height right? Thought it was the springs that affected amount of drop.
Old 12-24-2010, 07:58 PM   #16
Dreamliner330
My Ride: 330xi
I don't think those will work. Koni does not make FSD for XI...Check the Koni site.
http://www.koni-na.com
Old 12-24-2010, 08:16 PM   #17
Dan99
My Ride: 2001 330xi
thread saved.
Dan99 is offline   Reply With Quote
Old 12-24-2010, 08:17 PM   #18
Dan99
My Ride: 2001 330xi
so your total cost of everything after the installation was about $1650 dollars right?
Old 12-24-2010, 09:37 PM   #19
septalrage
My Ride: 2004 325xi
I stand corrected. Koni website list Part #2100 4005 as E46 318i, 323i, 325i, 328i, 330i compatible (Exc. Coupe, AWD, Touring and factory sport suspension). AJUSA website list the same part #2100 4005 but says compatible with XI models. I'll believe Koni website over the retailer. Koni FSD does not appear to be available for XI models, yet.
Old 12-25-2010, 12:10 PM   #20
Dreamliner330
My Ride: 330xi
I stand corrected.
I did TONS of research before buying...
Yes. And every wearable part of my suspension is brand new.
