Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 12-21-2010, 05:40 PM   #1
ilovebeemers
My Ride: 323i,325i, Boxster S
What mark do you fill up to on your dipstick?
I was wondering if you guys fill to top of the '1.1 quart mark' (green arrow) or to the top of the indented notch (bottom of the red arrow)?
2001 Porsche Boxster S; Black, 911 rims, exhaust, hardtop
2005 BMW 325i SULEV; Alpine White, Koni Yellow, H&R Sport, Chromed BMW Rims
1999 BMW 323i 5 speed; Black, Xenons, Koni & HR, Harmon Kardon, Premium & Cold Weather Packages
ilovebeemers is offline   Reply With Quote
Old 12-21-2010, 05:45 PM   #2
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
According to my manual It should be between the notch.
reynaldo is offline   Reply With Quote
Old 12-21-2010, 05:56 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If it's the correct dipstick for your model, then up to the bottom of the top notch is full.
If you're at the top of the top notch, you're a little over, but safe. A little over that top notch...starts becoming the danger zone.
Next complete draining of oil on level ground...add the amount your manual says to add. After you've driven and let it settle down...that's you're mark.
I let mine cool and drain down overnight...and, it appears I actually did have the wrong dipstick for years and used that for adding oil. Turns out, I'd been running about 5/8th qts. low for 3-4 years and never knew...so 'calibrate' your dipstick next oil change...in the meanwhile, I'd stay perfectly in the middle...or, for now, let it run lower and see if your oil sensor works! Maybe not!
(Sorry OP...someone is going to yell at me for writing all this stuff to you...sorry for getting you involved! LOL)
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
Old 12-21-2010, 06:01 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Isn't green half a quart low.
Old 12-21-2010, 06:03 PM   #5
todd92
My Ride: 05 330i ZHP
Anywhere in the top notch. Is this really that difficult to figure out?
FWIW your arrows are in the wrong places.
todd92 is offline   Reply With Quote
Old 12-21-2010, 06:10 PM   #6
dmax
dmax's Avatar
I tried to ignore asking about that reference...had no idea what that meant.
BTW, guy at dealer today was talking about his 2009 335 twin turbo diesel...something like 300 hp and 425 lb-ft...sounds like that'd be something!
Jake is right...that where your oil is at is where I think it ought to be until you calibrate dipstick. I know...it's a blessing and a curse!
D
Mangofy your E46!
Old 12-21-2010, 06:10 PM   #7
bimminge46
My Ride: 323Ci, 89 325i ETA
mine is right on the top notch below the red. I've put 6.2 quarts in it to fill it up during oil changes. The oil will read a little more when it is fully warmed up. Best time to check it is when it has sat over night then check it in the morning.
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 12-21-2010, 06:15 PM   #8
dmax
dmax's Avatar
Originally Posted by bimminge46 View Post
mine is right on the top notch below the red. I've put 7.2 quarts in it to fill it up during oil changes.
7.2 sounds like too much. 6.9 qts. in my 328i...you sure about fill capacity?
I'm going to leave before this gets too crazy!
D
Mangofy your E46!
Old 12-21-2010, 06:16 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
The top mark is Full, the bottom mark is a quart low. A typical dipstick will show 2 quarts low, or more, if off the bottom of the stick. Basically, if no oil shows you can dump in 2 quarts before you bother to check again.
Old 12-21-2010, 06:17 PM   #10
bimminge46
D
yeh it was i reedited it i couldn't remember how much I have been buying I buy 7 quarts and barely use any of the last 7th quart of oil.
E30 in progress.
Old 12-21-2010, 06:19 PM   #11
jdstrickland
On the example shown, the car is a half quart low. Since you cannot buy a half quart of oil, then ignore it. When it is a full quart low, add one.
Old 12-21-2010, 06:20 PM   #12
bimminge46
Couldn't you just buy a half quart and pour it in it. Then drive it a while check again and use the rest of the half quart if it read another half quart low?
E30 in progress.
Old 12-21-2010, 06:20 PM   #13
snowborder142190
My Ride: 08 335i coupe '09 m6
why is it so hard for a top car company to put a full and low line on it and it says full and low right on it. All the other car companies do it why not bmw?
snowborder142190 is offline   Reply With Quote
Old 12-21-2010, 06:20 PM   #14
jdstrickland
You buy 7 and use them all if you change the filter. The car holds 6.9Q on an oil change. The 0.1Q overfill is completely inconsequential. Add 7 quarts when you change the oil.
Old 12-21-2010, 06:23 PM   #15
bimminge46
My car doesn't use all 7 (6.9)quarts. I have 120k miles.....I fill and check and will not over fill my engine.
E30 in progress.
Old 12-21-2010, 06:26 PM   #16
jdstrickland
You are looking at the stick wrong. The top notch is the one nearest the handle, the bottom notch is the one nearest the tip. In your example, the top notch is the red arrow.
Old 12-21-2010, 06:32 PM   #17
jdstrickland
You are mistaken. The vehicle specification states 6.9 US quarts. There is no distinction for 4 or 6 cylinder motors. There are no US destination E46 cars, so there's little point in giving the spec for a motor that is not here.
Old 12-21-2010, 06:36 PM   #18
jdstrickland
You are reading the dipstick wrong, that's why you do not use 7Q of oil. You are filling to the BOTTOM line, not the TOP line. The bottom line is the one nearest the end of the dipstick, the blue line in the attached picture. The red line is the top line, and it takes just a half-cup less than 7Q to fill the oil to this line.
Old 12-21-2010, 07:07 PM   #19
ilovebeemers
Its a question. Not my pic. Just wondering wat others thought especially since the bmw pic points at the notch
Sent from my DROIDX using BimmerApp
Old 12-21-2010, 07:17 PM   #20
itsskoop
My Ride: '02 325ci
7 quarts if you drain completely.
itsskoop is offline   Reply With Quote
