E46 Xi Forum
Old 12-24-2010, 06:03 PM   #1
e36-2.0
My Ride: 330xi
Xi Oil Pan Gasket Replacment
So I just went check if all is well under my car and I found my oil pan gasket needs to be replaced soon. There evidence of oil seaping out of the engine block and the oil pan. Although its not anything severe, this will need replacment in due time.
Has an Xi owners performed an oil pan gasket replacment yet? Looking for an Xi specific DIY as our oil pans are not the same as regular e46s.
Any help will greatly be appreciated. Thanks in Advance!
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 12-24-2010, 06:11 PM   #2
colo330xi
My Ride: 01 330xi
Haven't seen a DIY on this, but my 2 cents on this is that M50/52/54 engines like to rattle the front oil pan bolts loose. I had this happen on my 230k mile 525i. Cinch up bolts, leak gone.
The oil filter housing gasket can make it look like all sorts of things are leaking, check near it if you haven't replaced it.
colo330xi is offline   Reply With Quote
