DSC / ABS / BRAKE Light HELP!!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-27-2010, 06:10 PM   #1
JcLusso
My Ride: BMW 335i xDrive
Send a message via AIM to JcLusso
so down in ny we got a blizzsrd snd after driving down my block in my 2003 325xi my abs, dsc and brake light got stuck on. i have driven around alll day and its still on. Any help would be appreciated.
JcLusso is offline   Reply With Quote
Old 12-27-2010, 06:36 PM   #2
shanneba
My Ride: 2003 330Ci
Get the DSC / ABS codes read, Peake code readers can't read these codes. You will have to go to dealer or a good BMW independent shop with the equipment to read these codes.
A quick search using your thread title, finds 373 threads with info with DCS / ABS and Brake lights, here a few you might look through to learn about the ABS/DCS systems and issues.
http://forum.e46fanatics.com/showthr...bs+brake+light
Here is a good document on E46 DSC systems -
http://www.kinmak.com/downloads/doc/m3training/TSC1.pdf
The Xi version is a little different but the document should still be a good overview of the system.
Join BMWCCA
Old 12-28-2010, 02:16 AM   #3
xi_ter
My Ride: 2003 325xi
Remove the wheels and remove and clean the speed sensor on each wheel. Check for damage to the top of these sensors.
Old 12-28-2010, 07:37 AM   #4
SMUUUUUV
My Ride: 330CiC X5 4.4-MBS550
^^^ this....
SMUUUUUV is offline   Reply With Quote
Old 12-28-2010, 07:42 AM   #5
crunkd
My Ride: 328i
these lights came on 3 weeks ago and the car wasnt even moving!! after i restarted the car it was fine can cold affect these sensors?
crunkd is offline   Reply With Quote
Old 12-28-2010, 09:34 AM   #6
JcLusso
where are the sensors?? Can anyone please advise... picture maybe?
Old 12-28-2010, 11:05 AM   #7
E46 S54B32
My Ride: 323ci
each wheel has 2 wires leading to them one is the brake pad wear sensor the other is the speed sensor, you need a hex key to take off
-oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl
E46 S54B32 is offline   Reply With Quote
Old 12-28-2010, 11:34 AM   #8
//TRD power
My Ride: 3.0 | 200hp | 214trq
Drive it again on dry pavement, it should reset.
//TRD power is offline   Reply With Quote
Old 12-28-2010, 12:17 PM   #9
JcLusso
the highways are clear and I drove about 2-4 miles on one. No luck.
Old 12-28-2010, 11:02 PM   #10
dephantn
Location: Toronto Canada- Family's EX :745i & X5 - 525i-323i
My Ride: 740iL-325xi
any light comes off, you need to read the code before you get help or fix.
PEAKE SCANNER OR OBD II or any other scanner can read code.
I have 325 XI 2002, both scanner can read those ABS/DSC code. (Even before, can read ABS/DSC code on X5-2003 too),
unless my cases not the same code?
For E46 enthusiastic/fannatic want to DIY & save $$$$, minimum should have Service manual , code reader & wrench set.
With out them, you may spend more $$$ then you save & some time you break more $$$ than save.
dephantn is offline   Reply With Quote
Old 12-28-2010, 11:09 PM   #11
TrickTizzle
My Ride: 325i
Peake scanners cannot read DSC/ABS brake codes. You need to get the car hooked up to Autologic/MoDic/GT3 computer to pull the codes which is something only GOOD indy shops and dealers have.
OP. Its most likely your front abs pulse generator that is causing the problem if your brake light is NOT red. I suggest cleaning those first followed by a road test.
Old 12-28-2010, 11:29 PM   #12
xi_ter
My Ride: 2003 325xi
This is what they look like after undoing the bolt and pulling them from the hub.They are located bottom right of each wheel. There is a cable you can follow coming from each sensor.
Old 12-29-2010, 10:49 AM   #13
JcLusso
Pulse generator meaning the sensors on the wheels? Where is this pulse generator you speak of?
I also just got my OBDII to USB cable the other day so im going to try getting the DIS Software running so I can read the codes.
Old 12-29-2010, 12:58 PM   #14
JcLusso
my rims are pretty open so I was able to reach / see the sensor. they look like nothing is blocking them... what do you clean them with?
Old 12-29-2010, 12:59 PM   #15
TrickTizzle
My Ride: 325i
ABS Pulse generator and Wheel speed sensors are the same thing. Take the wheel off and there will be a sensor behind the hub with a wire leading out.
Unscrew that with an allen key and clean sensor gently with a wire sensor...
Old 08-07-2011, 08:15 PM   #16
CruzBMW
My Ride: 2001 BMW 325ci
Dude! "right side" you mean driver side?
CruzBMW is offline   Reply With Quote
