Old 02-23-2013, 10:10 PM   #1
AvS
My Ride: 04 zhp AA II
Steam through vacuum leaks?
Wondering...can I use water-based steam cleaner to find air leaks? I have one with dry steam option...lots of steam. Or it's a bad idea...for sc..engine..close pipe at throttle body maybe? Searched around net couldn't find anything, what u guys think??
AvS is offline   Reply With Quote
Old 02-23-2013, 10:33 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I've read and believe that you co...uld just use a water bottle/spritzer and pick up vac leaks, you'd certainly notice a dip when it gets to the engine. Old school method of decarbonizing engine is what I hear.
I wouldn't put steam into it like that. Can't say why, but it sounds like a bad idea to me...intake doesn't get that hot usually...nor would many sensors and the like...you could use a cigar and just blow it in manually...but water mist should be noticeable. Guys also use carb cleaner and spray it around too...listening for a change in rpms.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 02-25-2013, 12:36 AM   #3
AvS
Yeah...just not everywhere u can reach spraying. Cigar method may not give enough pressure to open up leak. Interesting that nobody tried steam machine...or saying anything about it
Old 02-25-2013, 03:52 AM   #4
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Hate to cross post but there are quite a few cheap and easy ideas here for testing for vacuum leaks.
http://www.bimmerfest.com/forums/sho....php?p=4519113
