Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 08-31-2011, 01:58 PM   #41
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
This week's Weekly Special is P21S Gel Wheel Cleaner - 500ml Kit.
Use Coupon Code WSGELWH3511 to receive it for Free. A $17.99 value! Min spend $70. Offer ends 9/6/11 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Old 09-07-2011, 07:14 AM   #42
This week's Weekly Special is Poorboy's World Wheel Sealant - 8 oz.
Use Coupon Code WSWHEEL3611 to receive it for Free. A $19.99 value! Min spend $115. Offer ends 9/13/11 at 11:59 PM EST.
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Has an amazing watermelon scent that everyone loves!
  • The thinner the application the better, which allows you to get dozens and dozens of applications
  • Apply with a foam applicator pad or soft cloth and remove with a clean microfiber towel
  • Extremely easy to apply and remove, feels ultra slick upon completion
  • Prevents brake dust from etching in to the wheels finish
Old 09-14-2011, 07:36 AM   #43
This week's Weekly Special is DI Brushes Leather and Vinyl Scrub Brush.
Use Coupon Code WSLEATH3711 to receive it for Free. A $3.99 value! Min spend $15. Offer ends 9/20/11 at 11:59 PM EST.
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
Old 09-21-2011, 07:19 AM   #44
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt.
Use Coupon Code WSSHEEP3811 to receive it for Free. A $9.99 value! Min spend $55. Offer ends 9/27/11 at 11:59 PM EST.
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Old 09-28-2011, 07:47 AM   #45
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 8 oz.
Use Coupon Code WSULTRA3911 to receive it for Free. A $9.49 value! Min spend $45. Offer ends 10/4/11 at 11:59 PM EST.
  • Very effective at cutting through deeper imperfections
  • Finishes down nicely, but we still recommend a finishing polish after 105
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Old 10-05-2011, 07:41 AM   #46
This week's Weekly Special is Stoner Invisible Glass - 19 oz.
Use Coupon Code WSINVIS4011 to receive it for Free. A $5.99 value! Min spend $35. Offer ends 10/11/11 at 11:59 PM EST.
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old 10-12-2011, 08:00 AM   #47
This week's Weekly Special is SONAX Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL4111 to receive it for Free. A $15.99 value! Min spend $90. Offer ends 10/18/11 at 11:59 PM EST.
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • High quality spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
Old 10-19-2011, 07:52 AM   #48
This week's Weekly Special is DI Microfiber Waffle Weave Drying Towel.
Use Coupon Code WSWAFFL4211 to receive it for Free. A $17.99 value! Min spend $65. Offer ends 10/25/11 at 11:59 PM EST.
  • One of the best options for drying your vehicle and most commonly used by professional detailers
  • The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
  • Our microfiber waffle weave towel has silk edging to minimize adding imperfections
  • This towel can hold up to 5 times its weight with water
  • We recommend using the sheeting method prior to drying with the towel for maximum efficiency
  • Always wash your microfiber products prior to first use
Old 10-26-2011, 07:42 AM   #49
This week's Weekly Special is TUF SHINE Tire Appearance Kit.
Use Coupon Code WSTIREA4311 to receive it for Free. A $39.99 value! Min spend $160. Offer ends 11/1/11 at 11:59 PM EST.
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone***039;s that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
Old 11-02-2011, 08:21 AM   #50
This week's Weekly Special is Black WOW Black WOW - 4 oz.
Use Coupon Code WSBLACK4411 to receive it for Free. A $24.99 value! Min spend $170. Offer ends 11/8/11 at 11:59 PM EST.
  • Restore faded and neglected trim pieces, while leaving behind a bold even finish
  • Removes product residue from trim and lasts through multiple washes
  • Only a tiny bit of product is needed, use sparingly
Old 11-09-2011, 08:45 AM   #51
This week's Weekly Special is DI Brushes Lambs Wool Duster.
Use Coupon Code WSLAMBS4511 to receive it for Free. A $11.99 value! Min spend $25. Offer ends 11/15/11 at 11:59 PM EST.
  • Click product for complete description
Old 11-16-2011, 08:47 AM   #52
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 32 oz.
Use Coupon Code WSULTRA4611 to receive it for Free. A $26.99 value! Min spend $225. Offer ends 11/22/11 at 11:59 PM EST.
Old 11-23-2011, 08:38 AM   #53
This week's Weekly Special is Einszett 1Z Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP4711 to receive it for Free. A $10.99 value! Min spend $60. Offer ends 11/29/11 at 11:59 PM EST.
  • One of the best interior cleaners and protectants that leaves your finish factory new
  • Easy to get streak free results every time, great scent, and UV protects
  • Best used on your dash, gauge cluster, navigation screens, audio components, shift knobs, arm rests, leatherette, steering wheels and much more
Old 11-30-2011, 08:55 AM   #54
This week's Weekly Special is P21S Total Auto Wash - 1000ml Refill.
Use Coupon Code WSTOTAL4811 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 12/6/11 at 11:59 PM EST.
  • One of the most versatile products we offer, degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
Old 12-07-2011, 08:58 AM   #55
This week's Weekly Special is Menzerna Super Intensive Polish SI 1500 (PO83) .
Use Coupon Code WSSUPER4911 to receive it for Free. A $29.99 value! Min spend $185. Offer ends 12/13/11 at 11:59 PM EST.
  • Most noted for its ability to easily remove imperfections, good work time, easy removal process and brilliant finish
  • You will instantly notice more gloss and depth with just one application
  • Can be applied by hand but optimal results are with a buffer and an Orange or Cyan Light Cutting Pad from Lake Country
  • A premium medium to heavy cutting polish removing visible surface imperfections while finishing down remarkably well
Old 12-14-2011, 08:48 AM   #56
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL5011 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 12/20/11 at 11:59 PM EST.
Old 12-21-2011, 08:58 AM   #57
This week's Weekly Special is Meguiar's Professional Masking Tape - 1.5.
Use Coupon Code WSPROFE5111 to receive it for Free. A $4.50 value! Min spend $25. Offer ends 12/27/11 at 11:59 PM EST.
  • Properly protect trim, emblems, lights, adjacent panels and more when polishing or using a buffer
  • Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
  • Perfect for protecting clear bra edges so you don't get product build up that shows
Old 12-28-2011, 08:58 AM   #58
This week's Weekly Special is Chemical Guys Black on Black - 11 oz.
Use Coupon Code WSBLACK5211 to receive it for Free. A $12.99 value! Min spend $50. Offer ends 1/3/12 at 11:59 PM EST.
  • One of the most unique trim restorers that turns faded trim back to a deep factory black finish
  • Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
  • Formerly referred to as Chemical Guys Fade 2 Black
Old 01-04-2012, 08:28 AM   #59
This week's Weekly Special is Meguiar's Ultra Finishing Polish M205 - 32 oz.
Use Coupon Code WSULTRA0112 to receive it for Free. A $27.99 value! Min spend $205. Offer ends 1/10/12 at 11:59 PM EST.
  • Removes swirls and light imperfections on any type of paint
  • Finishes down haze, hologram and marring free
  • Perfect follow up to Meguiar's Ultra Cut Compound 105
  • Commonly used with a white polishing pad or a black finishing pad
Old 01-11-2012, 09:47 AM   #60
This week's Weekly Special is Chemical Guys Extreme EZ-Creme Glaze with Acrylic.
Use Coupon Code WSEXTRE0212 to receive it for Free. A $16.99 value! Min spend $80. Offer ends 1/17/12 at 11:59 PM EST.
  • The perfect prep step before applying a sealant to enhance the gloss and depth of any color paint, while hiding minor imperfections
  • The acrylic based formula makes it compatible with both sealants and waxes
  • Best applied with a foam applicator pad as thin as possible and removed with a microfiber towel
  • When using a buffer, best applied with a black finishing pad
