Sponsored by BimmerWorld
Old 01-02-2011, 01:24 AM   #1
ajai
My Ride: 330ci***65104; 328i
Steering wheel very loose
I got a problem when my car go highway speed the steering wheel become very loose. And it's seems very not stable. It get pull left and right on the road alot. Will it because of my blowen shocks or what? I have already changed a whole new aligement . The whole set. It got a little better at first, after 3 month problem is back.
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 01-04-2011, 10:05 AM   #2
DontWriteGraff
My Ride: E36///M.TchnoHrdtop
You Most likely need control arms and new control arm bushings. Get under the car check your bushings. I recomend getting meyle hd control arms and bushing check ecstuning they have a good price on them.
Sent from my iPhone using BimmerApp
DontWriteGraff is offline   Reply With Quote
Old 01-04-2011, 10:20 AM   #3
ajai
I checked them seems ok. The shake on the arm and bushing seems good condition. I am thinking will the left and right side camber be not balance. And also check the rear Custer I think.
Old 01-07-2011, 12:19 AM   #4
genuity
My Ride: 2001 330iS
did you check the steering flex disc guibo?
genuity is offline   Reply With Quote
Old 01-07-2011, 10:12 AM   #5
Bake
My Ride: AW F10 535 M-Sport
My car felt exactly the same way. If they have more than 25k miles on them, replace your FCAB's and RTAB's.
Bake is offline   Reply With Quote
Old 01-09-2011, 12:14 PM   #6
BruceJ
My Ride: 2007 Z4Si 2003 330i
+1 it will get loose
Mods (E46)
MTECH II Bumper, Predator Chromiums, Homelink,
Bluetooth Retrofit, Miro 346 Wheels, First Aid Boxes, Orange TPMS
Repairs (E46)
GM5 Door lock relays
LCA's FCAB's, RTAB's
Cooling system overhaul
CCV annd OFMG
BruceJ is offline   Reply With Quote
