Old 01-03-2011, 07:03 PM   #1
Bmcknight01
My Ride: 2004 330ci
Exclamation What's a better tailight tint, VHT nite shades or Lamin-x film?
Asking to see whats more effective, Vht nite shade spray or dark Lamin-x film. I have eagle eye LED taillights on an 04 330ci.
Bmcknight01 is offline   Reply With Quote
Old 01-03-2011, 07:14 PM   #2
w0w
My Ride: '02 M3 Vert
film
daron
w0w is offline   Reply With Quote
Old 01-03-2011, 10:07 PM   #3
Bmcknight01
My Ride: 2004 330ci
Ight thanks
Old 01-03-2011, 10:39 PM   #4
codyfunk
My Ride: 2001 BMW 330ci
Film. I did the VHT and regretted it but that's a different story. The film is more even in darkness. The spray is inconsistent looks ricey and well, just looks like balls.
codyfunk is offline   Reply With Quote
Old 01-03-2011, 11:24 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
lamin-x
Old 01-05-2011, 07:05 PM   #6
tfoxsf
My Ride: 2003 325i
I just did my OEM sedan tail lights in gunsmoke lamin-x. Super easy and looks great. I just took my lights off car and did it one night while watching tv. Seems durable and easy enough to remove if you need to. I really like that it looks dark until you hit the lights and then it is almost the same brightness as with no film (especially the backup lights).
tfoxsf is offline   Reply With Quote
Old 01-05-2011, 07:08 PM   #7
Custom3
My Ride: HellRot 330CI
you know what they say about VHT nite shades...once you go black youll never go back
thats why film is better
Old 02-24-2011, 07:28 PM   #8
murda46
My Ride: 330i
is that gunsmoke?
Baltimoron 04' 330i 19's
murda46 is offline   Reply With Quote
Old 02-24-2011, 08:39 PM   #9
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
You can try this if you are not sure how it looks on your car.
Smoke your tail lights with 'Clear' Plasti Dip as a (Primer); Use Plasti Dip to tint your tail light / achieve smoke tail lights.
To accomplish reversable Tail lights Tint.
1. Using 'Tint Flim', you can only do it once. ($39.99) Reversable
2. Using 'VHT' Tinting Night Shade (@ Amazon $9.98) NOT Reversable
3. Using 'Clear Plasti Dip' as a base and apply Tint 'VHT' Night Shade ($9.98 + $5.98) Reversable.
Using 'Clear Plasti Dip' before applying anything that are permanent can be reversable to its original state.
This is only a experiment stage by applying to my broken clear corner
Apply a coat of 'Clear Plasti Dip' on Corner lens.
Two to Three coat of clear plasti dip should be enough.
After Two / Three coat should look something like this. Cloudy.
Once the 'Clear Plasti Dip' is dry apply a coat of 'Transparent Black Window Tint'
Wait for the tint to dry and apply more when see fit.
NOW! To take the Tint OFF!
Once the Plasti Dip is dried. I've applied the Transparent Window Tint; you can find it at your local Hobby Store.
This is how it looks now.
BMW /// 323i /// Sedan
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// DEPO corners /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 02-24-2011, 11:32 PM   #10
Bando13
My Ride: 02 325ci
You probably heard of this already but just incase you decide on lamin-x, enter "10off" for the coupon code or whatever to get 10% off its not much but hey better than nothing right :/
Bando13 is offline   Reply With Quote
Old 02-24-2011, 11:36 PM   #11
Owtlaw333
My Ride: 2009 Mazdaspeed 3 GT
That's because you don't know how to use a spray can.
With that said, unless you're willing to do quite a bit of sanding (you'll wanna clear-coat too) to get it smooth and glossy, don't bother with VHT. Just get the film. Otherwise you'll end up with a very textured finish.
Bringing it back for the new people...
productionof1.com
|||_Buy my photos?_|||
Owtlaw333 is offline   Reply With Quote
Old 02-24-2011, 11:40 PM   #12
Bando13
My Ride: 02 325ci
Oh n another thing u might wanna go for the charcoal black film cuz imo the regular smoked ones on my tail lights look kind of purplish n brownish frm the mix of its original red
Old 02-25-2011, 08:02 PM   #13
Mark T.
My Ride: 2003 325it
Go with the Film.
Once you get a couple scratches or rock chips on the painted one, it will look like garbage. The film should be stronger.
Mark T. is offline   Reply With Quote
Old 08-27-2011, 08:12 PM   #14
MikeOrkid
My Ride: E46 323i
I have always used the nightshades. As long as you put in good time to prep, gently sand at 1500 for pre-spray, spray a very light coat and let it dry for 10 min. Recoat 3+ times in 10 minute intervals. Spray to your desired shade. If you follow those steps, youll get a great smooth glossy outcome. Its really all in the prep and not over spraying and creating runs. Just my 2 and 1/2 cents.
Ive never had a chipping problem either. Stones, bugs, road debris, etc. Ill post a pic or 2 soon.
MikeOrkid is offline   Reply With Quote
Old 08-28-2011, 04:09 PM   #15
That-Guy
My Ride: '01 330i
Depends on what your best at doing, either spray paint or tint. They can both look the same if you know what your doing. I suck at window tints but great at paint so I use niteshade.
Certified Master Tech
That-Guy is offline   Reply With Quote
