Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
replacing rotors ONLY..is this a silly move?
ONLY my front rotors NEED to be replaced
I am considering going with the BMW Performance Rotors and replacing both front and rear BC the rotors on such a crazy sale right now (75/77% off msrp) Should I go ahead and replace the pads/sensors on all four corners as well while I'm at it or is this overkill for now since there's still "plenty of life" left on them (according to mechanic at RRT)?
#2 |
I have rarely heard of rotors needing to be replaced without pads, though it is possible if they are scorched or "warped", I say go for it, pads not necessary. And sensors definitely not necessary. In fact I have never replaced sensors on my e46 and now they are tied back because my current pads don't accept them.
#3 |
Silly to replace rotors without doing the pads. Do it all at once, bed the pads and do it right.
2001 330cic Jet Black
#4 |
The Brake Newbie!
Replace it all...Why Ruin a good set of rotors on a used set of pads?
-Anthony@BimmerBrakes |
#5 |
yeah I decided I'm going to go ahead and replace the pads too (Hawk high performance ceramics for blend of performance and low dust -- style 135 wheels have to be one of the worst to clean)
thanks for replies /thread
#6 |
where are they on sale?? link please
#7 |
ECS Tuning has them http://www.ecstuning.com/BMW-E46-330...All/ES2137045/
I believe they're only on sale/offered for 330i/Ci fitment
#8 |
My Ride: Has blue lights
If your pads still have "plenty of life left" (I miss the guys at RRT
) you can still use them. Get a piece of plate glass and some 120 grit EMORY cloth (not SANDpaper). Sand the pads flat in a circular motion til they are flat and smooth. Mount and motor on for a few hundred miles til the rotors "season" with numerous heat cycles of light/modrate use. Then bed the pads/rotors as usual. Have done this many times, each with great results. |
| Tags |
| brake pads, rotors |
