Sponsored by BimmerWorld
Old 10-10-2013, 01:40 PM   #1
abusiveteenager
My Ride: bmw 330i e46
Finding BMW Sport suspension springs
I have a 2002 bmw 330i with the sport suspension. one of my rear springs has broken and the car sits about an inch lower than it should. I am looking to replace the springs with stock OEM springs but i have had a hard time finding what i believe to believe the right ones.
My dad brought me this link
http://sohiperformance.com/hr/hr_spr.../i-238844.aspx
but my concern is the bottom that says lowers one to one and a half inches. is that from normal suspension or sport?
If anyone has a link to the correct stock sport suspensions springs i would be grateful. Also if anyone knows of anything else i should look into while i have the car undone. I have 102k miles on it so im sure there is a long list.
Thanks a lot
Jon_a_
abusiveteenager is offline   Reply With Quote
Old 10-10-2013, 06:37 PM   #2
jcns
My Ride: California
consider doing shocks and struts, control arms with new balljoints and bushings, add reinforcement plates to the shocks, rtab if they are bad, steering ball joints.
jcns is offline   Reply With Quote
Old 10-10-2013, 06:46 PM   #3
TnT817
My Ride: 01 330ci
Entire cooling system.
TnT817 is offline   Reply With Quote
Old 10-10-2013, 06:57 PM   #4
aldeghij
My Ride: 2003 330i
Jeez people, at least attempt to help this guy. http://www.ecstuning.com/BMW-E46-330.../OE/ES2535563/. Expensive for the whole set though. I'm sure you could find one at a wrecking yard though.... You could also try here: http://www.bmrparts.com/. They don't get great reviews, though I've bought a few things from them and they've been fine..... Good luck.
aldeghij is offline   Reply With Quote
Old 10-10-2013, 08:21 PM   #5
ian02
My Ride: 05 325ci
Give me the last 7 of your vin. I have a program that will give me the front and rear spring part #'s that were originally used on your car.
ian02 is offline   Reply With Quote
Old 10-10-2013, 09:12 PM   #6
tech9018
My Ride: BMW
If interested Pm me... I have a set of OEM 2001 330i sport springs.
My Ride:
2001~2979cc~4 Doors~ZSP~Sunroof Delete~No Folding Rear Seats~Schwarz
Mods:
Dinan TB~Powerflex~Koni~Eibach~AA TwinScrew~
...And a whole lot of maintenance
tech9018 is offline   Reply With Quote
Old 10-10-2013, 09:59 PM   #7
abusiveteenager
km20496 are the last 7 of my Vin Num. I have been looking into some springs on bravauto.com that will lower the car about 1/4 inch i should be able to get away with that. also thinking about doing struts and shocks any recommendations? I went through the history of the car (pestered my father for about a half hour) and the front suspension has had some work as i live in Michigan and rims were bent and replaced as well as the damage suspension components. going to look through the records now to see exactly when and what was done. thank again for the help Jon
Old 10-11-2013, 07:12 AM   #8
ian02
My Ride: 05 325ci
According to VIN # KM20496 which comes up as an 03/2002 330I 4 door with no sport suspension
The boxes/options in the picture I'm attaching were automatically filled in by entering your VIN.
Front Springs are 31 33 6 756 966
Rear Springs are 33 53 6 756 984
Old 10-11-2013, 01:05 PM   #9
abusiveteenager
You are correct. I just went and looked at the original window sticker and I do have the sport package. but apparently that does not include sport suspension. Did not know that. Since i can find the normal springs I'll probably just keep is stock. Thanks a lot you guys have been a huge help.
Old 10-11-2013, 01:16 PM   #10
Bino5150
My Ride: 99 323i
I just took all 4 sport spring off my car when I dropped it... If you're looking to get a set.
Bino5150 is offline   Reply With Quote
Old 10-11-2013, 01:18 PM   #11
ian02
My Ride: 05 325ci
Same with my car, Sport wheel, Sport seats, etc but not the sport package. So much for "all coupes have the sport suspension". Glad I could help man.
Old 01-21-2014, 06:15 AM   #12
N-AM 007
My Ride: 330ci 2001
Any idea what suspension mine has and part number replacements for shocks and springs? Vin JU62627
N-AM 007 is offline   Reply With Quote
