Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#41 | |
Just follow a DIY and you'll be good. One tip I may give you is to remove your electric fan when doing the install, if you dont it will hit the AC compressor when you are lifting up the engine on the pass side. Good luck.
#42 | |
Same flange on the bottom where the stock headers connect to right?
Thanks Quote:
Sent from my DROIDX using Bimmer App
![]() Jon Estrella ESS TS2 - VMR V710 19" wheels - KW Coilovers - 3.46 Diff - Macht Schnell 5mm Rear Spacers - BMW Performance BBK w/ floating rotors - BMW Performance Strut Brace - BMW Performance Air Intake - BMW Performance SSK/DSSR - Hawk HPS Brake Pads - SS Brake Lines - OEM M3 RTAB w/ Vorshlag Limiters - Meyle HD FCAB - TMS Sway Bars w/ adjustable links - AEM Digital Boost Gauge - Stewart w/p - 6K HID Fogs - Swain Coated Magnaflow headers |
#43 |
A lot of the E46 M3 guys use Ar20 or AR25 resonators to eliminate rasp, if some of you don't like how your car sounds with headers you could look into welding those into the exhaust.
Sorry for the slight thread jack; is anyone running headers with high flow cats? What type of power gain do you see with this type of setup? |
#44 | |
Thats why I recommend bimmerbrakes headers , hassle free install.
