Sponsored by BAVSOUND
Old 01-04-2011, 10:08 PM   #1
TR4G-
My Ride: '01 325xi, '90 325iC
Angry Is this for real?> did i just blow my amp???
i had my amp hooked up yesterday and it turned on and everything
today i switched artound my setup becuase i got a new HU. since it had worked the night before i didnt worry about the fuse order. I had the fuse in the amp in and the fuse in the power cable out. I then turned on the car, and the amp illuminated [still not sure becuase the circuit was not complete??] then i plugged in the inline fuse and the amp turned off!!!
i checked both fuses with a multimeter and they are NOT blown
DID I HONESTLY JUST F**K up my amp??!
i thought the fuse in the amp would blow if anything bad happened! and yes both fuses are the appropriate fuses
EDIT: PS, i legitamently just bought this amp!
TR4G- is offline   Reply With Quote
Old 01-05-2011, 01:09 AM   #2
deadpass
My Ride: 01 330i
if the fuse wasn't in the power cable then the amp shouldn't have power. do you have a capacitor you're using? check all your wiring, sounds like something got fussed up.
deadpass is offline   Reply With Quote
