Old 01-05-2011, 10:28 PM   #1
TrickTizzle
My Ride: 325i
Aftermarket headers + o2 sensor help needed...
I am getting sick of my service engine soon light being constantly on so in an effort to get it to turn off I bought a new post cat Bosch oxygen sensor from Napa autoparts. They said it is the OEM sensor but for some reason i am still having issues.
I was able to remove one of the original o2 sensors from the stock cats and that sensor has been perfectly fine, the new one however is giving me a code saying o2 sensor heater circuit intermittent. At first I thought there was something wrong with the ECU so I swapped sensors to see if the code would follow the sensor, and it did. It went from Bank 2 Sensor 2 to Bank 1 Sensor 2.
On my new o2 sensor I did not cut up the wire and hook it up to the o2 simulator just in case I would have to return it, but I don't think it should matter since I am getting a heater circuit error.
Any one have any thoughts on this?
Old 01-05-2011, 10:47 PM   #2
Steven747
My Ride: 05 330ci
yeah aa cover code so no cel simple as that dont needa worry aboutt o2 sensors and if they work or not.. its worth it
Old 01-05-2011, 11:01 PM   #3
TrickTizzle
My Ride: 325i
AA tune doesn't resolve the o2 sensor heater issue.
You still need o2 sensors, otherwise the car will throw a code.
My friend got a AA tune and still had a CEL.
Old 01-07-2011, 01:56 PM   #4
4dr05zhp6mt
My Ride: e66 Monaco Blue
Send a message via AIM to 4dr05zhp6mt
The AA software build I am using does prevent CEL's stemming from the Secondary 02 sensors, I don't even have secondaries plugged in.
Do you have 1 secondary 02 with a sim and 1 secondary 02 without?
2008 Monaco Blue e66
SOLD05 330i 4dr zhp 6MT Jet Black | AA C38-81 S/C, 80mm pulley, water/meth injection | AA headers | Vac Motorsport 248/256 FI cams |
https://www.4shared.com/account/home...edir=105531274 (link to INPA v5, GTv44, EDIABAS, EasyDIS
4dr05zhp6mt is offline   Reply With Quote
Old 01-18-2011, 09:56 PM   #5
TrickTizzle
My Ride: 325i
One sim, two sensors.
The simulator is a dual output.
Old 11-05-2013, 02:44 PM   #6
lucianoromero
My Ride: 2005 330ci
Eliminate post-O2 sensors entirely?
I have recently installed aftermarket headers. I am about to apply the O2 simulator. Could I unplug the post O2 sensors entirely while hooking up the simulator to the ECU?
THANKS!
lucianoromero is offline   Reply With Quote
