Australia
Old 01-06-2011, 04:45 PM   #1
aar0n_91
My Ride: 04 BMW325CI///MSport
For Sale - Complete HK sound system + kicker sub and amp
first of all i live in sydney
okay so i have no need for the harman kardon gear that comes with an 05 325ci. it includes front speakers/tweeters, rears speakers/tweeters, 2 x 6x9 subs that are loaded in the boot attached to the rear deck, and the HK amplifier.
it all works 100%. its getting taken out of my car on mon, tues, wed next week so if you want to hear it over the weekend, something can be arranged.
im also selling my sub and amp that i have installed. it sounds good. it is the kicker kickpack as seen >>>>> http://www.jbhifionline.com.au/car-s...p-combo/435920 . it all works perfect.
as for price, this is the harman kardon gear for sale on ebay http://shop.ebay.com.au/i.html?LH_Av...op=3&_sticky=1
the only kit for sale is for a vert and is AUS$457 + postage. im open to offers but would love something around $350
and the kicker stuff, which i purchased for $449 from strathfield car radios (receipt is somewhere, ill try find it and post in here) was put on ebay when i first got the car, but i decided to keep it. it sold for $245 + 20 postage (without wiring kit). im after just over $200 and am open to offers. my wiring kit (to connect amp to battery and HU) is sony and was $90 from strathfield car radios. if the price is high enough ill include that as well
ideally id like pick up and one person to take it all, but both items can be sold separately and items can be posted (buyer can find the cheapest for them, and arrange it).
HK kit will be sold all together and kicker gear together. will not split that up.
i await all comments and feedback.
BMW 325 CI ///M-SPORT INDIVIDUAL
aar0n_91 is offline   Reply With Quote
Old 01-06-2011, 08:06 PM   #2
aar0n_91
open to all offers, but if its crazy low, obviously i wont accept
Old 01-06-2011, 09:00 PM   #3
Ballistic325
My Ride: slow and steady
Do you know if the HK speakers are plug and play for a non-HK set up in a sedan?
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 01-06-2011, 10:22 PM   #4
aar0n_91
to be 100% honest im not sure. i will find out, or someone else can chime in if they know. i dont see why not
Old 01-06-2011, 11:12 PM   #5
infini
My Ride: BMW 325Ci M Sport
not completely sure but you may need to check the radio harness in the rear and make sure the pins are not the round type as the 2005 plugs a flat pins.
<a href=http://s1084.photobucket.com/user/quachy1/media/e46%20SAM%20meet%2009-12-2012/_DSC0940.jpg.html target=_blank><img src=http://i1084.photobucket.com/albums/j412/quachy1/e46%20SAM%20meet%2009-12-2012/_DSC0940.jpg border=0 alt= /></a>
infini is offline   Reply With Quote
Old 01-07-2011, 12:15 AM   #6
Ballistic325
^ thanks. I have the round pins but even so, the speakers have connectors already in the doors etc so shouldn't they just connect straight in and work?
Might do some digging on the tech forums to see....
Cheers
I can help with
* RTABs
Old 01-07-2011, 12:22 AM   #7
fgin
My Ride: e46 facelift
the 6.5" speakers should just plug in AFAIK. They are almost the same as stock but I think paper coned 2 or 3Ohm instead of 4Ohm which is stock.
fgin is offline   Reply With Quote
Old 01-07-2011, 02:04 AM   #8
aar0n_91
Harman Kardon speakers
12-speaker system consisting of:
3 way set in the front of the vehicle
o Tweeter - 37mm/1.5inches overall diameter. The dome is about .5-.75 inches. 3 ohms
o 2.5" midrange - (Top of door next to tweeter) - 60mm/2.3inches overall diameter. 37mm/1.5inches deep. 53mm/2.0 magnet diameter. 4 ohms
o 6.25" mid-bass driver - (Bottom of door) - 160mm/6.29inches diameter metal speaker basket overall. Cone is 120mm/4.75inches. Overall depth/height of speaker 65mm/2.5inches. Overall magnet diameter is 71mm/2.8inches. The overall diameter from bolt-hole to bolt-hole on center is 190mm/7.4inches on the PLASTIC mounting flanges, of the adaptor the speaker is mounted in. Speaker is marked 21watt, 3ohm.
2 way set in the rear of the vehicle
o 2.5" midrange (same as above)
o 6.25" mid-bass driver (same as above).
Two 6x9" subwoofers mounted to the underside of your rear deck.
Old 01-07-2011, 07:14 AM   #9
aar0n_91
i dont know this for sure, but doesn't the radio harness have to do with the HU, which is not part of the sale, so flat pin, round pin, whatever is irrelevant?? as stated, all speakers/subs/amps part of the HK system are part of the package, and then my aftermarket sub and amp are also for sale.
Old 01-07-2011, 08:28 AM   #10
Scotty_89
My Ride: 2007 335i Coupe
Yes, but the speakers are different impedance.
This means you will need the HK amplifier with the speakers. I don't know much about the HK system, but there needs to be a connection between the Amp and the HU somehow...
Scotty_89 is offline   Reply With Quote
Old 01-07-2011, 04:19 PM   #11
aar0n_91
regarding impedance, HK amp IS included along with the speakers. with respect to the connection between it and the HU, it is plugged straight into my TV screen HU. when its un-installed, i can take a pic of what sort of connection it is (hopefully)
Old 01-07-2011, 08:26 PM   #12
Scotty_89
Yes, and my point is that there must be some harness between the amplifier and the source (head unit), correct?
Old 01-07-2011, 08:39 PM   #13
aar0n_91
well yea, but thats not an issue. no matter what sort of connection i or you have, there would be an adaptor which nullifies the problem. this is assuming they are different, when in fact they may be the same.
Old 01-08-2011, 03:07 AM   #14
Scotty_89
It's not about what I've got - I was simply saying that they may not be plug and play:
Cheers
I am saying that you should not just "plug and play" the HK speakers with Non-HK amp, and visa versa. The impedance does not match the amp specs and you are likely to cause problems.
Old 01-08-2011, 05:45 PM   #15
aar0n_91
^^^^^can not buy the speakers without the amp. im selling a package so that is irrelevant.
Old 01-09-2011, 11:48 PM   #16
aar0n_91
SOLD HK set. pending payment
sub and amp still for sale.
Old 01-10-2011, 05:37 PM   #17
aar0n_91
kicker sub and amp will be going on ebay if there is no interest so get a bargain guys. believe me, it does sound good.
Old 01-11-2011, 03:24 AM   #18
aar0n_91
deposit taken on HK set by member. kickpack is still for sale. if anyones interested, pm me or just mention it here.
Old 02-01-2011, 07:25 PM   #19
aar0n_91
both items are sold
Old 02-03-2011, 12:47 AM   #20
steve.k
My Ride: 05' 325Ci, 13' WRX
i will buy your rims? lol
steve.k is offline   Reply With Quote
harman kardon, kicker, sale
