Old 06-17-2011, 04:43 PM   #1
aphhpa
My Ride: 2001 330Ci
Send a message via AIM to aphhpa
What do I check next?
I've had "oxygen sensor adaption limitation" in all cylinders for more than a year. Ive replaced disa, maf,, lower and upper intake boots. The car randomly performs bad. Like sometimes it is just awfly slow, other times it's okay. It's gradually getting worse. I'm
Leaning towards my u2 sensors or icv next. Suggestions?
aphhpa is offline   Reply With Quote
Old 06-17-2011, 04:44 PM   #2
My Ride: 2016 Lexus
sooo you've replaced everything except the part named in the code?
Old 06-17-2011, 05:03 PM   #3
Zchild
My Ride: 2000 BMW 3XXi ZSP
I would suggest you replace the O2 sensors pre-cat which is the easy possibility but it sounds more like your Crankcase Vent Valves (CVV) hoses are probably cracked and need replacement. I had some of the same symptoms and it turned out to be my CVV hoses. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 06-17-2011, 05:21 PM   #4
aphhpa
My Ride: 2001 330Ci
I didn't think the oil separator had much to do with oxygen sensors. I had work done on my oil separator from BMW since the codes started more than a year ago. I think they would have caught it, or I'd like
To think so.
