Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 01-08-2011, 12:56 AM   #1
ajai
My Ride: 330ci***65104; 328i
Spacer made my suspension soften
I am on eibech pro springs, and stock sport shocks. I amrunning 18 rims. I install spacer yesterday the car is more comfortable. But it's really bouncy and my car scrape on bouncy road. That's so annoying. Will this also affect my cornering ? If so do I need new shocks? Before they were install the car is stiff
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 01-08-2011, 03:23 PM   #2
Recon2005
My Ride: VF-E 328Ci & 325 E90
Spacers shouldn't affect your suspension; are you sure the "scrape" you are hearing isn't your tire against the fender?
Vortech // Magnaflow // Hotchkis // H&R
Originally Posted by Forcefed M3 View Post
Could not agree more. I enjoyed my vf kit to the day I took it off. VF best s/c out there. Period
Recon2005 is offline   Reply With Quote
Old 01-08-2011, 04:12 PM   #3
hamadyr
My Ride: '05 330i ZHP
I second that motion.
With Eibach Pro, the "scrape" you are hearing is the tire rubbing on the fender. Most probably, rear fender.
Spacer will affect "twitchiness" of the car and amplify imperfections be in the suspension on the road. This because by adding the spacer, you are decreasing offset of the wheel and thereby altering the "scrub radius" of the suspension, affecting its response frequency.
Take those sapecrs out my friend, you are only accelerating wear on your suspension and bearings. Spend the money on new shocks instead ...
hamadyr is offline   Reply With Quote
Old 01-08-2011, 11:40 PM   #4
ajai
So there is no point for me to get new shocks? I check the tires doesn't seems to be scrape , and when I push hard on the car the fender don't touch the tires too. Let's have some detail for u guys. I am on 18x8.5 et45 20mm spacer. Camber -2.00, changing camber will make it not good to drive in highways so I don't want that.
Old 01-09-2011, 08:43 AM   #5
Recon2005
Run some blue painter's tape (or something comparable) on the inside lip of your fenders...if your tires are rubbing, the tape will be marred. You are probably not going to manually compress the suspension while the car is still to the point that it rubs.
Old 01-09-2011, 10:17 PM   #6
ajai
That is a great idea! Will try that out today
Old 01-10-2011, 03:23 PM   #7
VMRWheels
VMRWheels's Avatar
My Ride: 1:25 Scale Enzo
As it has been mentioned before, a spacer should not affect the shock's dampening at all. Rubbing will happen depending on wheel and tire sizes. It sounds like you're running a fairly aggressive setup with those spacers on, so it wouldn't be unreasonable to think that any scraping sound you might be hearing is from the tires.
Kevin @ VMR | Wheels
Tel: 714-442-7916 | Email: kevin.a@velocitymotoring.com
Facebook! | Flickr! | Blog!
VMRWheels is online now   Reply With Quote
Old 01-11-2011, 11:34 AM   #8
hummer
My Ride: 2001 330CI
You have stock shocks with lowering springs. How many miles on the OEM shocks? My guess is that you need new sport struts and shocks. But, they won't stop the rubbing problem. How thick are the spacers? Spacers move the wheels further outboutboard and thus increase the lever arm length so to speak of the suspension arm and may result in a softer feel and bounce. Especially if the shocks are weak.
