Old 01-08-2011, 05:10 PM   #1
apollotrance1
My Ride: '02 330i, '05 GSXR1k
Oxygen Sensor Purchasing
Where is the best place to purchase o2 sensors??? I my front 2 need to be replaced. OEM are $177 each, which is alittle out of my price range if I was to buy 2 of them right now. USautoparts.net sells Bosch and Denso o2 sensors for my car right around $60-$70. I think they are also aftermarket OE replacements. Any good ideas???
For a '02 330i
apollotrance1 is offline   Reply With Quote
Old 01-08-2011, 05:50 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
NGK makes NTK oxygen sensors, I run them in my 330ci, good luck.
http://www.ngksparkplugs.com/part_fi...?engineid=2113
http://www.amazon.com/NGK-25569-Oxyg.../dp/B001PNCMYI
SUMMIT POINT WV 1:24:229 SCCA
Old 01-12-2011, 07:38 PM   #3
apollotrance1
Any other places available??
Old 01-12-2011, 08:17 PM   #4
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I would find out the Bosch part # and go on ebay. A pair should cost about $120 at the most.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 01-13-2011, 08:42 PM   #5
TrickTizzle
My Ride: 325i
$80 at Autohausaz.com
Old 01-13-2011, 09:41 PM   #6
bigjae1976
bigjae1976's Avatar
Is that each? Ebay had the 4 wire Bosch sensors for $65 ea plus shipping.
Old 01-15-2011, 08:57 PM   #7
TrickTizzle
My Ride: 325i
$80/each.
If your ok with ebay you can go that route.
I hate ebay, so I stick with online vendors.
Old 01-23-2011, 05:48 PM   #8
NicB.
My Ride: 2000 BMW 328i
you can get them from autozone online...part number 13477 -- $71.99 ea.
NicB. is offline   Reply With Quote
Old 01-25-2011, 12:44 AM   #9
Nando779
My Ride: 2003 325Ci
Try rockauto.com they have good prices for spark plugs and oxygen sensors.
EDIT:
Looks like they have the post Bosch sensors for 62.79 but the pre are way more. There are some Delphi o2 sensors for post and pre for 54.79 but I have never heard about Delphi o2 sensors.
Nando779 is offline   Reply With Quote
