Thread Tools Search this Thread Rating: Thread Rating: 53 votes, 5.00 average. Display Modes
Old 04-10-2014, 08:37 AM   #21
bmwbob89
My Ride: M-5 325 X3 528 740
Clear the fault and see if it returns. This was what BMW used to tell us. If it returns you will probably need a DME. There are some companies that rebuild them and sell rebuilt units. Google will help you find them. Look for BMW bulletins about this or ask the dealer to look for you. There is one pertaining to this. One of my own X-3's had this issue and I had to get one. I bought it as a non running car and that was the issue with some other faults.
bmwbob89 is offline   Reply With Quote
Old 04-10-2014, 03:21 PM   #22
framesliding14
My Ride: 02 325i
If you don't mind me asking how much did you pay?
framesliding14 is offline   Reply With Quote
Old 04-10-2014, 06:53 PM   #23
TrickTizzle
My Ride: 325i
Did you check your battery yet? I'd bet its old and failing, causing electrical/electronic issues.
Old 07-16-2014, 03:56 AM   #24
veli510
My Ride: 2001 BMW 330i
i'm having this issue, i disconnected my battery for 2 days. still doesn't start even with a 2nd key. same issue, my dme is bad i guess. but i heard that if i buy a used DME, EWS, and KEY it will start right up if i swap them, not sure if it's true but i might go that route if someone can confirm this, thanks
veli510 is offline   Reply With Quote
Old 07-16-2014, 09:14 AM   #25
lszlszx
My Ride: 1.8T, XC70
Yes, it would start up, but the EWS is registered to another vehicle and you would have difficulty obtaining a new key when you need it.
Just buy a used DME and have a shop code it to your car.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 07-16-2014, 09:34 AM   #26
jfoj
My Ride: 330CiC, M5, X5
Little to no useful info you are posting here other than the car does not start with a 2nd key.
Then you think the DME is bad "my DME is bad I guess" and want to replace the DME, EWS and Key, this is like killing an ant with sledgehammer.
How about a bit of background with a clear description of what is happening if you want any useful responses and ideas?
Read the link in lszlszx signature for No Start Problems.
Old 08-02-2014, 08:18 AM   #27
keithb32
My Ride: e46 330ci
Hi Guys
I have a problem with the e46 that sounds pretty close to this one, it would intermittently not crank. It's getting worse and now very hard to start. I've plugged it in and worked out that it was not getting the key code (Diamond shaped keys).
The 'key number' reading would fluctuate with random numbers flashing up, some in the hundreds, even though I believe there are only 10 key IDs stored.
With the key held in a certain position it would settle on 'key 1' and verify it and the car would start. Thinking the antenna was weak, I've just replaced it and no change. Both keys sometimes fail to work although sometimes trying the other key works, but seems to just be pot luck, not conclusively one bad key. As the key transponder is not battery dependant, would the expensive new key option be a waste? Neither key has been opened and both remotes work well.
I did initially see immobiliser faults when scanned ages ago, but these haven't returned while the problem has got much worse. I think the only one was in 'engine' and was immobiliser timeout.
The vehicle battery is not too clever but quite capable of starting the car when it feels like it!
Any ideas would be appreciated!
Keith
keithb32 is offline   Reply With Quote
Old 08-02-2014, 08:50 AM   #28
jfoj
Keith
"Vehicle battery not to clever"
If you have any concerned about the battery, I would replace that long before I would dive into anything else, cheap, easy and quick and it could be a contributing factor. Stable and good battery Voltage is important for modules to properly communicate and function correctly.
Old 10-02-2015, 01:52 PM   #29
Thory4
My Ride: 2003 325i
Happened to me for the first time and ordered me the spare key.
They had 3 options: plastic valet, metal valet, and regular key with remote. I bought the metal valet key and the no crank issue has not come back so far, has been a couple of weeks.
Thory4 is offline   Reply With Quote
Old 07-10-2016, 10:21 AM   #30
dleef
My Ride: 2004 330ci 6spd MT
EWS in key remote
i had a problem with one fob that could start the car, and one that couldnt.
Thus i knew the problem was with the EWS circuitry in one of the key fobs. i cut open the key, and It turned out the solder joint on the inductor coil was bad (even though it looked fine). i re-heated the joints with a soldering iron and EWS started working. also changed the battery while in there to get my keyless entry working.
Be very careful cutting open your keys- use a knive and go very slowly, and dont damage any components on the keys's PCB, many people do and destroy components.
E46 330CI DIY
Mods:
Hawk HPS 5.0, Painted Calipers, KONI Yellows, MeyleHD RTABs, MelyeHD Control Arms+FCABs, Motor & Tranny mounts, UUC EVO3 SSK+DSSR, UUC Sway Bar, Interior LEDs, clutch stop, Front Lip, Performance Headers
Repairs:
VCG, OFHG, OPG, re-packed tensioners, GM5 relays, remote transmitters, PS Pump, VANOs, Starter, Flex disc, transmission seals, wiper motor adjust, interior door seals
dleef is offline   Reply With Quote
Old 12-12-2016, 11:27 PM   #31
smokey325i
My Ride: 325i 2003 Sedan
Man, been avoiding to head to the dealer but I have a trip this thursday and my 13 year old FOB stopped working today! How much did you pay for the spare key?
smokey325i is offline   Reply With Quote
Old 12-13-2016, 12:03 AM   #32
jfoj
About $155 online - http://forum.e46fanatics.com/showthread.php?t=1008294
e46, ews, fuse, key, start
