Old 01-11-2011, 07:53 AM   #1
Maxgraphix
Banned
My Ride: 2002 BMW 325ci
Guess I'm gettin the Shark Injector
After installing the Ram Air box on the 325 I noticed hesitation off the line. I've been told that since I'm now gettin more air I need more fuel and more advanced timing. So far I think the Shark Injector will be the best and easyist install (and cheapest). Anyone know of a deal better than the 299.00?
Maxgraphix is offline   Reply With Quote
Old 01-11-2011, 08:32 AM   #2
kpeng
Banned User
My Ride: E46 330 and E30 325
An intake does not change the air flow significantly enough to need software adjustment. It doesn't change the amount of air your car sucks in, just the temperature. I'm more inclined to believe you messed something up during the install. Check your MAF connections and clean the MAF sensor. Also check if all the tubing has been tightened up properly.
kpeng is offline   Reply With Quote
Old 01-11-2011, 08:37 AM   #3
mal1110
My Ride: 2001 325i
^+1
You don't need to modify anything to make an intake work better. It's just to keep the air cooler. Most intakes barely do anything (except look cool) anyway.
mal1110 is offline   Reply With Quote
Old 01-11-2011, 10:02 AM   #4
brosive05
My Ride: 01 325 & 94 ZR1
The hesitation is probably the fact that your not getting enough fuel released from your cat.
Student during the day, driver at night.
brosive05 is offline   Reply With Quote
Old 01-11-2011, 10:08 AM   #5
jgold47
My Ride: 2004 X5 3.0
how old is your flux capacitor?
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 01-11-2011, 10:44 AM   #6
Saloon
My Ride: E46 330i, E36 Ms, X5
Send a message via AIM to Saloon
Saloon is offline   Reply With Quote
Old 01-11-2011, 11:56 AM   #7
Blocked Out
My Ride: Imola 330i M-Sport
You have an air leak somewhere, find it.
Sent from my X10a using Bimmer App
Original BMW Teile ///
IMG_1725
Old 01-11-2011, 12:48 PM   #8
Maxgraphix
Banned
My Flux Capacitor is always new - when I think its wearing out I go back in time and get a new one!
Old 01-11-2011, 12:50 PM   #9
Maxgraphix
Banned
I've had the intake on for 2 years now and the hesitations always been there. I've checked for leaks or bad connections, but I'll check again. Thanks, Guys
Old 01-11-2011, 01:00 PM   #10
Iceman00
Banned User
My Ride: E90 6MT
Get the shark anyhow, it was worth 14whp with the addition of an intake for me.
Old 01-11-2011, 01:02 PM   #11
MasterTJ
My Ride: 2002 e46 BMW M3 6sp
Originally Posted by mal1110 View Post
^+1
Wrong. If an intake changes the piping size, more air flow results. On my Lexus I got a 3" intake (much larger than stock) and a piggyback chip that came with it. The chip adjusted the air fuel ratios. Not only was the air cooler, but there was more of it flowing in. This resulted in a 9rwhp gain (i dynoed the car to check the gains after putting the intake in). Anyways, gains and such always vary, but to say that all intakes do is change the air temp is wrong. Larger tubing/better bends/higher flow filters allow for more air to come into the engine. If chips and piggybacks change A/F ratios to be more lean (use less fuel, more air), they can change it all they want with this increased airflow. The ratios can be changed without increasing airflow as well (using stock airboxes) but overall, larger piping/higher flow filters will absolutely allow more air into your engine's intake system. They are not just "for show". You may be saying they're "for show" because they provide little gains, if any sometimes, but to say they do absolutely nothing is plain wrong.
Sent from my iPhone using BimmerApp
2002 BMW E46 M3 Black 6sp
Borla / CF goodies / Kenwood/Infinity sound system / Orion V2 AE's
1st Lt, USAF
MasterTJ is offline   Reply With Quote
Old 01-11-2011, 01:13 PM   #12
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
The stock dme compensates 7% for 2003.5 and up MS45 and 15% for MS43 pre 2003.5s
so infact the computer does add for the increased airflow without throwing a light.
Conforti's shark will help with the added airflow all thrown into calculation, and the added pedal responsiveness and 7k redline and removed top speedo isnt that bad for the price.
Its one of those things you do to top off the mods on the car. Its also a must if you have a higher ratio differential and need more road speed in each gear.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 01-11-2011, 01:14 PM   #13
BMWPartsSource
Internet Sales
BMWPartsSource's Avatar
My Ride: n/a
We sell them !!!! www.bmwpartssource.com
BMWPartssource.com
BMWPartsSource is offline   Reply With Quote
Old 01-11-2011, 01:21 PM   #14
323I00
My Ride: E46 323I
This Is why youre loved and hated.
323I00 is offline   Reply With Quote
Old 01-11-2011, 01:21 PM   #15
kpeng
Banned User
None of the aftermarket intakes for our cars change the intake tubing size.
Old 01-11-2011, 01:31 PM   #16
Iceman00
Banned User
My Ride: E90 6MT
Doesn't matter what he or you think, he is wrong. The ecu can only adapt so much, not to mention it isn't going to add ignition timing, or adjust the vanos outside the factory specified range. Give it up, both of you.
Old 01-11-2011, 01:37 PM   #17
kpeng
Banned User
Are you serious? A CAI is not going to affect the car enough to need software adjustment. It absolutely does not.
Old 01-11-2011, 01:41 PM   #18
Iceman00
Banned User
My Ride: E90 6MT
Notice I wasn't asking you anything. I told you, and I have dyno plots to prove my point. What do you have, hearsay?
Old 01-11-2011, 01:49 PM   #19
MachRc
E46Fanatic
MachRc's Avatar
any one remember that old school simota intake
Old 01-11-2011, 01:53 PM   #20
emmm_three
My Ride: ML350/325i/330ci/M3
I never got this joke for the longest time...then I asked someone and they said it's a reference to a movie in the early 80's...then I'm like no wonder...that was back when Dinosaurs were around
emmm_three is offline   Reply With Quote
