Old 01-11-2011, 05:29 PM   #1
dansxtreme
My Ride: 2000 Bmw M3 Clone
Retrofit 2003 LED Tails to 2000 using same LCM
Gentlemen,
I am in the process of installing/ modifying a set of LED taillights out of a 2003 E46 convertible to replace my standard translucent tails in my 2000 E46 convertible. I am hoping to use resisitor to burn off the energy so that I do not have to purchase a new LCM.
Has anybody read about this? I am having problems finding info... There also seems to be a harness which can be purchased, but would this be required in this case?
Dan
ID:	389431   Click image for larger version
dansxtreme is offline   Reply With Quote
Old 01-13-2011, 12:57 PM   #2
dansxtreme
Bump- Nobody's done this?
Old 01-13-2011, 02:43 PM   #3
infinite012
My Ride: White '08 STI
Seems pretty straight forward. Find a +12V and ground that activates with the parking lights, turn signals and brakes.
infinite012 is offline   Reply With Quote
Old 01-14-2011, 05:48 AM   #4
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
It's possible. You just have to present the right load to the LCZ (LCM) and whola, no more light out warnings unless there really is a problem.
You'll have to keep increasing the resistance until you find the required level (load) to stop the warning from triggering.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 01-14-2011, 01:11 PM   #5
dansxtreme
I believe connecting 12 v directly to the led board on the light would burn them out. This is why resistors are installed before the board? If I can get this working, then I can look at how to get rid of the lights on the cluster. Most likely by buying and reflashing a LCM.
Dan
Old 01-17-2011, 08:58 PM   #6
dansxtreme
OKay guys I think I had this wrong. After some research I found that I need the adapter from the halogen connection to the LED connection (Part # 61120153650). With this alone I believe they led lights will work but present the tamperdot on the cluster. This can be removed by getting a new LCM or installing resistors before the old lcm.\
Does this sound correct?
Old 01-17-2011, 09:03 PM   #7
TerraPhantm
My Ride: M3 & ZHP
With that adapter the LEDs will work, but there will be lights-out warnings. You don't get a tamper dot unless the the LCM is replaced with one that's tied to another car.
In theory, you can remove the lights-out warnings w/ the appropriate resistors. Officially, you're supposed to upgrade the LCM to one that supports LEDs
Old 01-17-2011, 09:16 PM   #8
dansxtreme
When the new lcm is reflashed, is there an input for the odometer reading? I wouldnt want the odometer reading to be higher than what it currently reads if the new lcm is higher?
Old 01-17-2011, 09:39 PM   #9
TerraPhantm
My Ride: M3 & ZHP
If the VINs match, the LCM will pull its mileage from the instrument cluster. If the VINs don't match, no mileage info is altered (but there'd be a tamper dot).
Old 01-19-2011, 07:14 AM   #10
MitchSF
My Ride: 11 M3 DCT
Yes, and you want to use the highest value resistors that will eliminate the warnings. The higher the value, the less heat will be generated. The LEDs will not burn out with any resistor value, but using a value that is too low will generate too much heat. A very low value, maybe 5 ohms or less approaching a short circuit, could possibly damage the LCM or cause it to shut down if it has a protection circuit.
If you're looking for the lowest aggravation factor, get a new LCM or find someone who can recode a newer, used LCM for you.
MitchSF is offline   Reply With Quote
Old 01-25-2011, 03:57 PM   #11
mosill
My Ride: E46 M3
Send a message via AIM to mosill
Perhaps you could build a test set up with a like a 50K pot and adjust from 50k down till you find the right resistance. Then measure the resistance on the pot with a DMM and just wire in a real resistor at that value.
mosill is offline   Reply With Quote
