Old 01-11-2011, 05:49 PM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
OEM electric fan question...can you separate the fan?
If you have an electric fan (like the one that comes with a MT), can you separate the fan from the fan shroud?
My shroud is damaged but the fan works fine. I've got some zipties holding securely but I would feel much better if I could replace the shroud.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-11-2011, 07:17 PM   #2
Tangent_
My Ride: '01 330i, '11 Z435i
Since the shroud it what's holding the fan to the radiator you'd have to replace the damaged shroud with a good one. Since that's not a separately available part you might as well just replace the entire fan assembly.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 01-11-2011, 11:58 PM   #3
bigjae1976
bigjae1976's Avatar
Actually there is a part number for just the shroud on Real OEM and ECS sells it. I'll post it later...
