Sponsored by BimmerWorld
Old 01-11-2011, 06:27 PM   #1
autosri
My Ride: 330ci clubsport
ebay special camber plates
hey all im a member from to uk dont really post much on here but do read quite a bit
im looking to add some camber to the front end i keep seeing the usual kmac gc eibach ect but are all pretty expensive by the time they get over here to me
was browsing ebay as you do and stumbled across these
http://cgi.ebay.co.uk/BMW-E36-318-32...ht_1317wt_1141
they seem to cheap to be true i know they are for an e36 but look identical to mounts for the e46 although dont have adjustable caster so emailed the seller for sizes and got this back
what do you guys recon btw im on coilovers but not sure what diameter the piston thread is
thanks guys
autosri is offline   Reply With Quote
Old 01-13-2011, 11:21 AM   #2
ECSTuning
ECSTuning's Avatar
My Ride: BMW
You might want to also consider UUC!
The experts at UUC produce high quality parts for BMW enthusiasts. Though they are often much less expensive than many performance aftermarket parts, quality is not compromised.
High performance racing parts and accessories from a company built by racing enthusiasts. With a full line of quality suspension, braking, and other parts, it's easy to customize your vehicle while giving a unique driving experience.
Made from aircraft quality aluminum, these precision machined components incorporate an OE style bearing within a bonded urethane insulator that doesn't rattle or loosen up like a spherical bearing will.
Providing as much adjustment capability as anyone should ever need, these are equally at home on the street or on the track.
Front Camber/Caster Adjustment Range:
Camber: -2.0 to +2.0
Caster: -.75 to +.75
Best,
Joe
