Old 01-11-2011, 08:05 PM   #1
alpine325coupe
My Ride: 2004 M3 SG/IR
Removing Stock Xenons and Installing H7 HIDs
So I wanted to go from 6000k to 8000k. I got a cheap kit online. I have installed 9006 HIDs on 2 cars in the past so I thought these would be a breeze. I was wrong. I ended up taking out the 2 lamps and taking them to pieces. I disconnected the stock xenon ballasts and found a way to use the new kit. However, the new kit had one loose red wire and one black, both with metal tips. I ended up getting the lights to work without ever connecting them to anything. Now when I turn on my HIDs, sometimes all my meters (RPM, MPH, fuel, temp.) flicker for a second and then go back to normal. This also resets my clock, trip calculator, mpg, and all that jazz. Did I botch the install? Does anyone know what those 2 wires connect to?
Thanks in advance
alpine325coupe is offline   Reply With Quote
Old 01-11-2011, 08:52 PM   #2
xi325xi02
My Ride: 325xi
Im confused.. you ditched your hid setup for h7's???????????????????????
Originally Posted by onebad328i View Post
you want ladys damm, get a punchin hard ass sound system
I HATE CVT'S
xi325xi02 is offline   Reply With Quote
Old 01-11-2011, 08:55 PM   #3
alpine325coupe
yea...knowing the end result i know i probably chose to do the wrong thing. I took out the xenons for an H7 HID kit
Old 01-11-2011, 08:56 PM   #4
jose325i
My Ride: 08 BMW 135i
If you wanted to go to 8000k, all you needed were different bulbs.
jose325i is offline   Reply With Quote
Old 01-11-2011, 08:56 PM   #5
alpine325coupe
it sounds stupid. i basically tried to swap the stock hids for aftermarket hids, just a different color
Old 01-11-2011, 08:57 PM   #6
alpine325coupe
after i did the installation it hit me that i could have used different bulbs. anyway...how do i fix my current problem?
Old 01-11-2011, 09:09 PM   #7
jerseyfresh
My Ride: is schwartzed out
Originally Posted by trhine View Post
FYI you look like a over weight fortune cookie.
^^^Directed @Kpeng^^^
jerseyfresh is offline   Reply With Quote
Old 01-11-2011, 09:10 PM   #8
jcns
My Ride: California
replace with OEM and buy the bulbs you want.
jcns is offline   Reply With Quote
Old 01-11-2011, 09:58 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
Thanks in advance
Why are yo doiing this?
HIDs are an upgrade to H7s. I'm not saying you can put HIDs where H7s go, I'm saying you wish you had HIDs instead of H7s in the first place.
You are making a giant leap backwards. You are asking how to replace the mercury vapor yard light with a candle.
Old 01-11-2011, 10:00 PM   #10
TrickTizzle
My Ride: 325i
'10
Old 01-11-2011, 10:22 PM   #11
haurelio
My Ride: 2001 bmw 325i
this sounds like a short problem.. just put everything back and change ONLY the bulbs(d2s) to the temp that you want..
Old 01-11-2011, 10:26 PM   #12
e46pauler
My Ride: '05 330i ZHP
Cheap HIDS are NOT shielded electromagnetically ... they'll cause your radio to buzz when you turn them on and possibly interfere with any other electronics.
Congrats.
e46pauler is offline   Reply With Quote
Old 01-11-2011, 10:29 PM   #13
Lusticles
My Ride: 325Ci
Congrats.
You're saying that like it is a definite.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 01-11-2011, 10:30 PM   #14
jdstrickland
Congrats.
READ IT AGAIN!
He's taking the HIDs out of the car, not putting them in.
Old 01-11-2011, 10:40 PM   #15
e46pauler
Originally Posted by jdstrickland View Post
READ IT AGAIN!
Well then ... that makes no logical sense at all.
Old 01-11-2011, 10:44 PM   #16
N89
My Ride: 330Ci
I never understood wtf H7 HID bulbs were... aren't H7 halogen?
N89 is offline   Reply With Quote
Old 01-11-2011, 10:54 PM   #17
alpine325coupe
H7 is just the size of the bulb. I didn' think the ballast would be compatible with another bulb color, hence the replacement. However, I am retarded and acted spontaneously. I cut the wires for the stock ballast but made sure that I left enough wire so I could reconnect them god forbid I messed up. I'll be kicking myself when I'm sitting there reconnecting the wires at about 6 spots.
If you all want to take shots at me, go for it. Its very well deserved.
Old 01-11-2011, 11:13 PM   #18
snowskateskate
My Ride: 2001 330ci man.trans
yea, I think they are
snowskateskate is offline   Reply With Quote
Old 01-12-2011, 05:39 PM   #19
haurelio
as above is only the bulb/connector type. you can find h7 halogen as well as h7 hid kits.
Old 01-12-2011, 07:04 PM   #20
TerraPhantm
My Ride: M3 & ZHP
H7 sockets are designed for halogens, but some companies put H7 bases on HID bulbs so that they can make plug and play bulbs. These bulbs are almost always inferior in quality compared to proper D2S bulbs... And H7 housings aren't optimized for HID bulbs, so the light output usually sucks too.
electrical problem, headlights, hids
