Old 01-12-2011, 12:39 PM   #1
dcaron999
My Ride: 2002 330xi
Differential output seal
My 2002 330xi with 90,000Miles has developped at leak on the rear differential output dustcover, on the passenger side. On a few occasions, Ive cleaned the diff housing with brake cleaner, and inspected soon thereafter, to confirm where the leak was coming from. Today, I opened the fill plug while I was under there, and stuck my finger in the fill hole to determine if there was still enough fluid in there. My finger touched the oil about 1/2" to 3/4" below the fill hole. I took a few pics today before cleaning up. The pics are attached to this post.
Can I avoid dropping the differential to simply replace the seal?
Do I simply need to replace part #12, and should I tackle both sides? The driver side looks challenging due to the exhaust in the way ...
10 dustcover plate, large 33131428097
11 dustcover plate, small 33131214298
12 Shaft seal with lock ring 33107505604
13 Lock Ring 168K/L 188K/L 33131214961
See RealOEM diagram, and my pics below.
ID:	389525   Click image for larger version
Name:	differentiel 330xi 002.jpg
ID:	389537   Click image for larger version
Name:	differentiel 330xi 003.jpg
ID:	389538   Click image for larger version
Name:	differentiel 330xi 006.jpg
Name:	differentiel 330xi 008.jpg
ID:	389540   Click image for larger version
Name:	differentiel 330xi 014.jpg
ID:	389541   Click image for larger version
Name:	differentiel 330xi 017.jpg
dcaron999 is offline   Reply With Quote
Old 01-12-2011, 01:42 PM   #2
M1992
My Ride: 02' E46 330i
Not sure man, but if you come around to getting that seal. Id get it from Pelicanparts.com, they have a wide range of parts for Bimmers, like that seal, that come at cheaper price than most sites out there. Good luck to ya though!
Originally Posted by captjones
my dad used to pat me on the head when i had very short hair & said:
"son, u'd make a fine toilet brush"
M1992 is offline   Reply With Quote
Old 01-12-2011, 05:43 PM   #3
hamadyr
My Ride: '05 330i ZHP
I just replaced my diff two days ago.
All you need is part # 12, the seal.
With the diff in the car, you should have enough room on the passenger side to unbolt the halfshaft from the diff and drop it down far enough to have clearance to "pop out" the output flange (Careful not to damage the cover.) and replace the oil seal.
All in all, with a lift, it would take about an hour and half ...
One hour to get it all out and half an hour to put it back together.
hamadyr is offline   Reply With Quote
Old 01-12-2011, 06:28 PM   #4
dcaron999
My Ride: 2002 330xi
Thanks for your tip. Nice to know you are from my area too. By this phrase "with a lift ...", are you implying supporting/lifting the diff or axle, while replacing the seal?
I just ordered a pair of seal + lock rings from Pelican Parts and a LISLE TORX EXTERNAL SOCKET SET 8PC #26750.
Total of $65 for all.
Will I need to drain the oil first to avoid spillage via the output opening, or does the output shaft sit high enough above the bath?
Thanks again.
Old 04-06-2013, 06:23 AM   #5
nateo
My Ride: 2002 330ci
How do you get the output flange out of there without removing the diff? Doesn't seem to be enough room for a slide hammer.
nateo is offline   Reply With Quote
