Old 01-12-2011, 03:34 PM   #1
Egbert87
My Ride: BMW e46 320i
TPS sensor on E46 no M
Hello,
My 320I 2001 goes into limp mode after he gets hot. Only occurs when hot.
Did some research here and got faults codes checked P1639 & P1638 where logged. These are the throttle position sensors 1 & 2.
I used the search function but nothing came up solving my problem.
Can I replace the TPS sensors on a 320I?
Where are they located? (only found M version here)
Or should i replace the throttle body it self?
Thx!
for info:
P1638 Throttle Valve Position Control; Throttle Stuck Temporarily
P1639 Throttle Valve Position Control; Throttle Stuck Permanently
Egbert87 is offline   Reply With Quote
Old 01-12-2011, 03:58 PM   #2
Arty
My Ride: 1999 328i
TPS is bolted to the Throttle body. Looks like it needs a good clean (note - don't use carb cleaner on your teflon coated TB). Dig out an ICV (Idle Control Valve) cleaning thread from Google or search here. Budget 1 or 1.5 hours to do the job.
Your TPS is fitted with dual redundant carbon wiper potentiometers to measure throttle position. These throw a different code when one is worn out.
Arty is offline   Reply With Quote
Old 01-13-2011, 10:06 AM   #3
Egbert87
Oke thanks Ill try that.
I replaced the rubber tube to the Valve because it was cracked sucking false air in, cleaned the icv better did the throttle valve also while i was at it . Ill keep you updated!
Old 06-07-2012, 05:36 PM   #4
geewrd
My Ride: 2002 325i
Did this end up fixing your issue??
geewrd is offline   Reply With Quote
