#1 |
HELP: car is not responsive and accelerates at a slow...
Hello everyone.
I need help. I tried the search function but it was of no avail. Problem: Engine light came on... Car (2002 330i) stutters and feels like if it is going to turn off on idle. When I drive, car is not responsive and accelerates at a slow rate. I step on the gas pedal but car won't speed up like it should- It speeds up, more like constant but slow until it reaches the speed I want to go!! So, now car is in my garage. What could the problem be? I visually checked the hood and the underside but did not notice anything abnormal. Any help would be really appreciated. Has anyone experienced this problem? Thank you, for reading. Joey |
#2 |
Research camshaft position sensors. I'd say thats the first area you should be concerned about.
#3 | |
Joey, first and foremost...GET THE CODES PULLED!
![]() Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya. |
#4 |
#5 |
#6 |
autozone, fo freeeeeeeeeeeee
#7 |
dude codes checked
run the codes on the search bar and bam answers just desrcrbing it isnt going to do anything...misfire, cam sensor, vacuum leak it could be alot of things...go to autozone its free and youll know more or less what it is
![]() -oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl |
| Tags |
| 330i, accelerator, bmw 330i, non-responsive, slow acceleration |
