Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Old 01-13-2011, 12:17 PM   #1
Hector45
My Ride: 2002 OB 330i
How does auto trans cooler work?
I've searched to no avail, and am left feeling puzzled. How does the transmission cooler in our E46 automatics work?
What I do know:
There are two lines running from the transmission to the trans cooler/heat exchanger.
The trans cooler has what looks to be inlet and outlet ports that attached to the lower left part of the radiator.
There is an auto trans thermostat at the bottom of where the expansion tank attaches.
What I don't know:
I would think the trans cooler/heat exchanger does the cooling but if so why does it have inlet and outlet ports going into the radiator?
Were does the auto trans thermostat allow/block flow of fluid to? is it coolant or trans fluid it regulates?
Is there space in the radiator that is reserved for the trans fluid?
Thanks guys I can't seem to figure this one out despite looking at numerous photos and parts diagrams.
Hector45 is offline   Reply With Quote
Old 01-13-2011, 12:25 PM   #2
xavi330i
My Ride: 2004 330i smg
The cooler is integrated into the radiator. Seperate cooling channels.
xavi330i is offline   Reply With Quote
Old 01-13-2011, 04:36 PM   #3
afstud
My Ride: 2003 ZHP 6-speed
is it a bad idea to run the car without the whole tranny thermostat? mine broke and i got the entire thing out so its wide open, and i ordered a new one but wont be here for a week, what do you think?
afstud is offline   Reply With Quote
Old 01-13-2011, 04:45 PM   #4
BimmersGarage
My Ride: E46 330i
It would be best to wait for the new A.T.T. to arrive...
It would NOT be wise to run your vehicle without the trans. thermo.
You would end up with a lot of hot coolant flowing back down to the transmission cooler.
BimmersGarage is offline   Reply With Quote
Old 01-13-2011, 06:56 PM   #5
Sansho
My Ride: 2001 325i
This will explain how the transmission cooler works: http://forum.e46fanatics.com/showpos...&postcount=147 . Engine coolant both helps to warm the transmission fluid as well as cool it. This happens outside the radiator in the transmission heat exchanger.
Sansho is offline   Reply With Quote
Old 01-16-2011, 08:42 PM   #6
Hector45
Thanks alot Sansho
Old 01-16-2011, 08:43 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Some people buy aftermarket trans coolers as well
