Old 01-14-2011, 11:56 PM   #1
TheLastGreek
My Ride: 330ci
Not another ebay header thread. Ebay headers
I've read many eBay header threads and have one very specific question that was not addressed in the many threads I read. I have heard of ceramic wrapping/coating the headers and my question is what will happen if I don't? Will I get heating issues or error codes?
TheLastGreek is offline   Reply With Quote
Old 01-15-2011, 02:44 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by TheLastGreek View Post
..... I have heard of ceramic wrapping/coating the headers and my question is what will happen if I don't? Will I get heating issues or error codes?
No heating issues by not wrapping or coating your headers, but under hood temps will be lower if you do & it may be worth a very small amount of WHP. You will get error codes when you remove your CATS.
On a side note, wrapping your headers provides two small benefits.
1) If you run your knuckle into a wrapped header you might not get burned.
2) Wrapping provides a small amount of sound reduction.
SUMMIT POINT WV 1:24:229 SCCA
Rob43 is online now   Reply With Quote
Old 01-15-2011, 05:24 PM   #3
TheLastGreek
My Ride: 330ci
Much appreciated, I think I'm going to go with the spark plug trick with the shark injector. Even if the shark doesn't take off the code I feel that the shark > than AA because of the higher rev limit and lower cost.
Old 01-15-2011, 05:26 PM   #4
mvrk10256
My Ride: E30 325i
spark plug trick wont work. read my thread.
and AA >>>> shark. please search.
Old 01-15-2011, 05:38 PM   #5
MasterTJ
My Ride: 2002 e46 BMW M3 6sp
Well in terms of cost, the shark is less money and he may be on a budget. Also, there's no removing and shipping away anything. It has it's pros, but for cons you're probably referring to the quality of the tune and of course AA is better there, they do it per customer which is a more custom job and a higher quality tune. The shark is meant to be easy, quick, and have some positive effects as well. People will pay for easy and quick, this we all know.
Sent from my iPhone using BimmerApp
2002 BMW E46 M3 Black 6sp
Borla / CF goodies / Kenwood/Infinity sound system / Orion V2 AE's
1st Lt, USAF
MasterTJ is offline   Reply With Quote
Old 01-15-2011, 08:07 PM   #6
trippmann
My Ride: E30
Send a message via AIM to trippmann
wrapping headers can also cause them to crack and form exhaust leaks. get them coated, it doesnt cost that much
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
