Old 01-17-2011, 08:03 PM   #1
Marley78
My Ride: 325I
55 watt HID
I recently installed a 55 watt HID kit. I had the 35 watt kit before and really like how much brighter it the 55 watt kit is. My only problem is that i notice a very faint intermittent flickering or pulsing if i stare at the beam for a while that goes from passenger side to the driver side bulb. Do i need a relay? or do you think that getting the dealer to unflash the car for xenons would help? i had my car flashed before to accept the 35 watt kit.
Marley78 is offline   Reply With Quote
Old 01-17-2011, 09:20 PM   #2
infinite012
My Ride: White '08 STI
You need a relay harness. And probably your ballasts aren't the best quality, so that could explain the pulsing.
infinite012 is offline   Reply With Quote
Old 01-17-2011, 10:14 PM   #3
Marley78
My Ride: 325I
ill try the relay harness. the kit is "digital HID". its the only 55 watt kit i could find. Do you know of others?
Old 01-17-2011, 10:40 PM   #4
infinite012
Morimoto.
The reason why you can't find other brands offering 55W HID kits is because they're unnecessary. If you put too much light onto the road, then you're saturating your eyes with what you can see, so your pupils will contract, hindering what you can see in the darker parts of the road. Another reason is because anything around/above 50W is probably going to be used in an industrial application (i.e. garage lights, road lights, etc.).
