Old 01-18-2011, 12:44 PM   #1
325_man
My Ride: 2003 325 XI
Question Window Regulator Bolts and Plastic Clips
Apparently the bolts and clips don't come with the regulator.
Does any one know where I can buy 2003 325xi window regulator bolts and plastic clip? How much do they cost?(see attached pictures)
Thanks!
Name:	BMW Reg Clip Bolt.jpg
325_man is offline   Reply With Quote
Old 01-18-2011, 12:51 PM   #2
My Ride: 2016 Lexus
You cant reuse your old ones? They should cost less than $5 per side. The obvious solution is go to your nearest dealer. They might not have them in stock though--i can't imagine that its a commonly stocked item.
Old 01-18-2011, 01:13 PM   #3
himefrankie
My Ride: 03 330xi
Thanks!
Looks like you want part numbers 2, 3, and 4 from this link below:
http://www.realoem.com/bmw/showparts...25&hg=51&fg=10
Try GetBMWParts.com, BMWPartsSource.com, AutohausAZ.com, etc..
go big or go home.
himefrankie is offline   Reply With Quote
Old 01-18-2011, 01:21 PM   #4
AJV
My Ride: 164 Quadrifoglio
I reused mine on my driver and passenger doors. If they aren't broken, you should just reuse them. If the tub nut (for lack of a better name) falls out the back, just press it back into the red piece - the bolt will will pull it nice and snug.
AJV is offline   Reply With Quote
Old 01-18-2011, 05:25 PM   #5
325_man
On the "Hex bolt", the note says "ENDED". Does it mean anything?
Old 01-18-2011, 05:41 PM   #6
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
You can buy these parts at your local dealer for a few bucks. Don't reuse them. They are known to break on their own and when they do your window falls right off of the regulator. Why risk having to go back in there again just to replace this little piece?
-Gary
DiscoStu is online now   Reply With Quote
Old 01-18-2011, 05:47 PM   #7
joneperry
My Ride: e46 + S60 + Z
http://www.clipsandfasteners.com/BMW...eners_s/20.htm
Your welcome
joneperry is offline   Reply With Quote
Old 01-18-2011, 05:48 PM   #8
My Ride: 2016 Lexus
I see what you're saying, Gary but it's extremely easy to pop the panel and vapor barrier and replace the clips. Usually I'd recommend replacing small things like bolts and plastic parts but in my case I was already knee deep in the job on a Sunday and just reused the old parts. They seemed to be fine and my windows function perfectly again. I could be wrong though.
Old 01-18-2011, 05:49 PM   #9
Mwise
My Ride: 330CI
These regualtors are used on many cars and trucks i.e. Ford trucks. So they are pretty available. They will break at some point. If you can get the plastic piece get it. It is worth it. The nut and bolt can be reused without any problem, that is unless they are stripped or rounded off.
Mwise is offline   Reply With Quote
Old 03-31-2013, 02:57 PM   #10
dancmos
My Ride: BMW 323i
Ignore the moron remarks - he needs the bolts, so do I
Thanks!
The bolts were gone on 2 of the window clips on my car, so I too need them. I appreciate the info that they're available at the dealer and that it's a good idea to change them. The guy who lambasted you for not "reusing" the originals didn't bother to RTFQ apparently.
dancmos is offline   Reply With Quote
Old 04-01-2013, 01:18 PM   #11
dancmos
My Ride: BMW 323i
I bought my dealer's remaining stock. The nuts (bushings is the correct label) were $1.13, the clips were .77.
Old 04-29-2013, 05:12 PM   #12
dancmos
My Ride: BMW 323i
Turns out window guide was twisted, kept breaking clips. $375 fix. Sigh.
Old 04-29-2013, 05:21 PM   #13
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
New clips, bolts and bushings/nuts are so cheap it's a no brainer...if your dealer has them. My dealer had 2 clips and 1 bushing in stock. I'd at least recommend new bolts because I nearly stripped the (very short) heads trying to remove and reinstall.
Old 04-29-2013, 06:51 PM   #14
dancmos
My Ride: BMW 323i
The window guide: not so easy
Old 04-29-2013, 08:15 PM   #15
David McMahon
My Ride: '99 E38 740iL
Turns out I must have put my nuts (bushings item 4) in backwards! Also I was going to ask about the vapor seal gunk, what is it called and what's the best to get? Do BMW sell that gunk in a tub or similar?
David McMahon is offline   Reply With Quote
Old 04-29-2013, 08:43 PM   #16
LeMansteve
The gunk is 3M Window Weld. My dealer sold it in a 15ft roll for like $10.
Old 04-29-2013, 08:57 PM   #17
David McMahon
Thank you, something else not easily obtainable in the UK, but I'll find similar, it did used to be on Amazon UK, but not any more.
Old 04-30-2013, 06:27 AM   #18
jayb328i
My Ride: E46 2000 328i
I must be stupid. I have changed the window regulators MANY times on my e46 2000. Never had a problem, and never was aware that the clips/bolts should be changed. Perhaps just lucky.
BUT--next time I will do that---perhaps my luck is running out. 13 years old, some of the windows had their regulators changed twice.
jayb328i is offline   Reply With Quote
bushings, clips, nuts, window regulator
