Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 01-20-2011, 12:56 AM   #1
tOekNee323i
My Ride: BMW 323i
BMW Speakers ? Amp? Wires?
I am having some problems with my speakers. My highs and mids are not working at all. The only speakers working are the lows/bass. The speakers i have are the 10 set BSW plug and play speakers. I also have a Kenwood KVT-614 in dash navigation.
At first the speakers would work and cut out, happening several times until finally they just never came back on. I bought a replacement OEM amp and that did not fix the problem. Tried checking fuse 7 and 41 and disconnecting the battery still nothing....
Does anyone (BSW rep) know what may be the problem? I went to a audio store and they quoted me 600 to replace an amp and rewire the speakers? (Not even sure that will fix the problem) Too me that seem steep... what do you guys think the problem is and if 600 is to much?
tOekNee323i is offline   Reply With Quote
Old 01-20-2011, 08:52 AM   #2
Evap
My Ride: rubs tires
This happened to me once, and I felt like a total idiot when it was solved. I'm not saying this is the case, but move around the wire loom that connects to your driver's side door panel. Sometimes, if a wire moves just right, it can get crimped in there. Just keep working it around and open/close your driver door quite a bit and see if that'll fix it. As for mine, they didn't work for a day or so, but lo and behold, I got back in the car one day, shut the door, and my speakers started working again.
Evap is offline   Reply With Quote
Old 01-20-2011, 10:31 PM   #3
tOekNee323i
My Ride: BMW 323i
so the wires from one of door panel can cause all the mids and tweeters to go out from all 4 doors? I will try it out tomorrow morning thanks.
Old 01-21-2011, 12:25 AM   #4
95seriesbmw
My Ride: BMW X5, BMW M3
check headunit outputs. also check to see if there is a loose connection from factory harness to the kenwood.
which speakers are working specifically? which door(s) or what location? im assuming you have no subwoofer correct?
95seriesbmw is offline   Reply With Quote
Old 01-21-2011, 09:01 AM   #5
Evap
My Ride: rubs tires
Yeah, I know that sounds strange, but none of my highs or mids were working, just the lows. A crimped wire in the driver's side door solved it.
