Old 01-20-2011, 07:07 PM   #1
williambrison
My Ride: 00 323i, 85 535is
hid question help please!
i ordered a set of hid for my high and low beams. i already installed the low beam and i am super happy with the result i am worried about the high beams since my daytime running light is thru the high beam. is there anyway to over ride the day time runners? i have a 2000 323i sedan and obviously not with the xenons. thanks for the help!
williambrison is offline   Reply With Quote
Old 01-20-2011, 11:58 PM   #2
Evap
My Ride: rubs tires
Don't run HIDs in halogen housings. It's really dangerous to other drivers and just looks tacky. Get some projectors.
A dealer or someone else with an equivalent tool has to code your DRLs off. As I just said in another thread, some dealers will try to over charge you for it, even though it's a quick process. I'd see if any indie shops around you can do it first.
Evap is offline   Reply With Quote
Old 01-21-2011, 12:16 AM   #3
williambrison
Not to be ignorant but how does a hid kit in my car make it dangerous to another driver?
Old 01-21-2011, 12:23 AM   #4
Evap
My Ride: rubs tires
HIDs in halogen bowls reflect REALLY badly. A projector style headlight focuses the incredibly bright light of an HID into a beam, where as with a halogen bowl, all of the HID's light is just reflected in every direction, including into the faces of other drivers.
90% of the time, when you're blinded by "HIDs," it's someone who just put HID bulbs in a halogen housing, because with properly aimed HIDs in projectors, the light doesn't blind other drivers.
Old 01-21-2011, 12:34 AM   #5
infinite012
My Ride: White '08 STI
HID kit in halogen reflector:
OEM with some slight tweaks:
You tell me which one looks better.
infinite012 is offline   Reply With Quote
Old 01-21-2011, 12:34 AM   #6
williambrison
That makes sense unfortunatly I got a little carries away with window tint (5% all around and 35% windsheild) so the added light was a asap must. Ill look into the projectors just never been a fan of there looks. Do you know if the dlr issue can be solved w a higer end scan tool? I own a small repair shop intown and it'd be embarassing to have to take my car the the dealership lol
Old 01-21-2011, 12:40 AM   #7
williambrison
Those pictures really helped. Thanks for the info guys
Old 01-21-2011, 12:45 AM   #8
Evap
My Ride: rubs tires
I'm not sure what tools can do it. Have a look around the software forum on bimmerforums. You'll be able to find all the coding information you could dream about there.
http://forums.bimmerforums.com/forum...play.php?f=233
