Old 01-20-2011, 07:49 PM   #1
isaiahj95
My Ride: 2002 BMW 330i
what size turn signal lights do i have?
i have a 2002 330i facelift sedan.
i want to get Chrome / Amber Halogen Turn Signal Bulbs
what size is recommended for me to get??
1156/7506, 194, or 7507.
isaiahj95 is offline   Reply With Quote
Old 01-20-2011, 08:07 PM   #2
chriscf17
My Ride: 1999 BMW 328i Sport
Link here.
chriscf17 is offline   Reply With Quote
Old 01-20-2011, 10:23 PM   #3
TerraPhantm
My Ride: M3 & ZHP
If you've got clear corners, you'll want PY21W. If you've got stock amber corners, then you'll want 1156. My personal favorite chromed bulb is the Philips Silvervision. Unlike all the other silver/chrome bulbs out there, these are as bright as stock.
(if you're using clears with your original sockets, you'll have problems fitting the PY21W bulbs... You'll need to figure something out though because that's the type that blinks yellow).
Old 01-21-2011, 01:20 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Your front bulbs are either 1156 or 7507. To make sure, take out the factory bulbs and look at the pins on the metal base. They will be offset by 150 degrees or 180 degrees. If they are 150 degrees- 7507, if they are 180 degrees- 1156.
The sidemarkers are 194 and the rear turn signals are 1156. Your reverse bulbs are also 1156.
You can either replace them with the Solaris Invisibulbs or the V3 LED Turn Signal Bulbs. Both options are available in amber or xenon white.
Hope that helps, let me know if you have any other questions!
