E46 Xi Forum
Old 01-21-2011, 12:33 AM   #1
Shevanel
My Ride: 2004 325xi
Exclamation 2004 325xi problems (smoking, rough idle shake)
Hey guys
Im new to the forum and i love it. Helped out a ton on other things!
First off just want to say i've read through alot of threads but i wanted to post my own with some specifics about my car. Basically i bought my 2004 325xi 2 summers ago. Since, I have had several problems with it (i think i bought a lemon except its not yellow or lemony fresh )-: although it does leave a sour taste in my mouth)
Problems i am currently having are:
A shake - mostly felt when the car is under load. It can get pretty violent at higher RPMs while climbing steep hills. Based on other forums ive read i think it might be my CV boots. Tomorrow i will put it on a frame lift and look for leaks. The shake seems to be in the rear end. My wife blew the driver side tire and we replaced it with the same one but with about 20% more tread. The shake didnt start until about a month ago and the tire has been on for at least 5 months.
Smoking - My car looks like a chain smoker at times and other times looks fine. sometimes at start up big billows of smoke, sometimes thick, others cant even see exhaust. I have recently did a DIY on a valve cover gasket. I did this atleast 2 months before the smoking, or i noticed the smoking. Also the smoke can look blue at times but i cant be sure. if it is blue its not overwhelmingly blue to suggest im chugging the oil back.
Rough idle - This too is a newer development. I started to notice it when the temperature dropped out here. (about -6c). But like my other problems it comes and goes, although, you feel it more often than not. Almost feels like it will stall. it is rougher when its in gear though.
I really appreciate the help in advance!
I reposted all this in a new forum incase its all connected.
Side notes: recently installed a new started, battery, did an oil change and a valve cover gasket)
Shevanel is offline   Reply With Quote
Old 01-21-2011, 12:40 AM   #2
nickchuck
My Ride: 325xi (Topaz)
Check your control arm bushings for the shake.
Make sure you properly sealed your VCG diy.
Check the DISA valve for the rough idle, could also be a software issue.
Good Luck sir, any one else have some guesses?
nickchuck is offline   Reply With Quote
Old 01-21-2011, 04:55 AM   #3
xi_ter
My Ride: 2003 325xi
If you live in British Columbia consider switching to Chevron with its Techron cleaning additive.
Old 01-21-2011, 09:44 AM   #4
SamDoe1
My Ride: 4cyl of fury
Shake: Probably the CV joints. If you've been going this long with that shake, they're probably toast. Plan for new axles.
Smoke: One of the CCV lines is probably clogged and forcing oil into the cylinder. This should be fixed ASAP before something bad happens. Also, check the valve cover gasket to make sure you did it right.
Rough Idle: Do you have an auto? If so, this is a documented problem without a documented solution. If you have a manual, try and clean the ICV and check the intake boots for tear/cracks. Also, make sure the DISA valve is in good working order. Do the same for the auto anyway.
You don't have a lemon, all of these are common issues and are easily fixed (except for the rough idle). What maintenance have you done on the car lately and how many miles does it have? These cars are very easy and relatively cheap to maintain but very expensive to fix. Which would you rather have? There's likely a lot more you need to do to it to keep it in good running condition.
Old 01-21-2011, 11:49 AM   #5
Shevanel
My Ride: 2004 325xi
Thanks for the help i will be checking these out tonight. I let the vibration go because i was told from 3 shops it was a wheel bearing so we looked at it and it is quiet with no play. Then was at a bit of a lose until ifound this site. My car has 190k and is automatic. Im an generally pretty good at keeping ontop of my maintenance until recent. I really appreciate help. Lets hope its just the CV joints :S is the a thread on here about checking ccv lines?
Old 01-21-2011, 12:06 PM   #6
SamDoe1
http://forum.e46fanatics.com/showthread.php?t=643639
That'll pretty much cover everything I listed except for the axles. Please note that you cannot change just the CV joint and you have to change the whole axle. It's not that hard but it is very time consuming so labor costs will be very high if you take it to someone.
Old 01-21-2011, 01:02 PM   #7
Kubica
My Ride: 2003 325xi
I agree with the CCV and DISA diagnosis.
Is it your right front wheel bearing that the shop said is the problem? If so, when mine went out, it didn't make noise when turned by hand. Only at speed.
If three shops said it was the wheel bearing- why the hell didn't you replace the wheel bearing?
Old 10-26-2015, 05:12 PM   #8
Marybmw
My Ride: 2004 BMW 325 xi
Angry I have a 2004 BMWXI with this problem too
I have to drive on the highway between 30-40 minutes at around 65 mph for the car to start shaking so much that it feel like it will fall apart in the middle of the highway. I just had the valve cover gasket replaced because oil was leaking on the manifold and making white smoke from under the hood that blew at me with the heat blowing, and the engine service light came on they said because it was a bad secondary vacuum that was just replace. I also noticed it shakes mor when going up hill. Mine only has 77,000 miles on it and I think it is a lemon too. Please help. I don't feel safe driving on the highway. What can I do to fix this?
Marybmw is offline   Reply With Quote
Old 10-26-2015, 06:07 PM   #9
Shevanel
My Ride: 2004 325xi
My solution
For me it was a 2 things. Smoke was due to a dirty oil separator (CCV). Time consuming but straight forward DYI. (I also did my spark plugs) The shake was caused by a broken DISA valve. When I removed my DISA it did not look broken at all but it wasn't opening properly which cause the shake. My car going up hill felt like I was driving on octagons not round wheels.
Old 10-26-2015, 06:16 PM   #10
My325XI
My Ride: 03 325XI Sprt Prem
Marybmw - your issue is most likely your CV axles. Very common problem with the XI's. Welcome to the forum. P.S. your post was replying to a thread that was almost 5 years old. Ues the Search function first, then create a new thread for your questions if needed.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 10-26-2015, 07:11 PM   #11
Shevanel
My Ride: 2004 325xi
If it was an axle it would be clicking while turning. Going up hill or down wouldn't make a difference for vibration. And you would feel it at every speed.
Old 10-26-2015, 08:51 PM   #12
Kubica
My Ride: 2003 325xi
Thank you for coming back and letting us know how it turned out...four years later.
You are incorrect about failing axle symptoms. I agree with the axle diagnosis for Marybmw. It's most likely the passenger side inner cv boot has lost its grease.
Old 10-26-2015, 09:18 PM   #13
Shevanel
My Ride: 2004 325xi
Hey no problem Kubica! Happy to help..
Marybmw. Next time your car starts shaking on the free way let off the accelerator and coast for a bit. See if the shaking is less harsh. Then accelerate and see if it comes back.
It doesn't make why an axle would shake more up a hill. You aren't going any faster, just the load on the engine is greater.
And FYI Kubica, when an axle joint starts failing it clicks. That is a well known symptom.
exhaust, idle, leak, shake, smoking
