Old 01-22-2011, 02:15 AM   #1
bvz
My Ride: 2000 e46 Touring
2000 Touring. Some small questions re: headlights, floormats, rattles, etc...
I have a 2000 323i Touring. I want to get a couple of things/fix a couple of things before I hand this car over to my parents. Parents who are in their 70's mind you... so this isn't going to be a thread about performance mods
Headlights:
First, the original headlight lenses on this car are in terrible shape. I tried buffing them out and after several hours it is better, but still not great. To that end I think I need to get new lights. Searching on these forums, it seems that umnitza is one of the more respected names in lights (there were some others as well and I am open to options). My questions are as follows:
1) Are sedan lights compatible with the touring?
2) How cheap can I go The boy in me really really wants Xenons and Angel Eyes but the bill paying adult is doing his best to smack that boy down. Do AE look stupid with halogens? Are there any more or less "stock" replacements that are cheaper? (obviously without the AE) If I do go nuts and decide to get Xenons, are they a plug in replacement for the current lamps or do I have to worry about error codes and the like? I have, like, 30 seconds of spare time per week and can't really be doing anything that takes more than a screwdriver to implement. - Basically I am cheap, but not cheap enough to try my luck with no-name lights from eBay. So what is the next best option?
Floormats:
Same basic idea here. The floormats that came with the car are the original BMW mats, but they slide all over the place and I hate the color (I want black ones). I'd like to get some cheap but decent mats that are specifically designed for this car and have some means by which they are fastened down. Any suggestions where to go, or can I just get some off of Amazon? I assume the touring uses the same mats as a sedan, correct?
Rear mat for cargo area:
The previous owner had no respect for the carpets in this car. They are a mess, including the rear cargo area. I was thinking of getting a big custom mat for that area. Any ones that people like?
Rattles and squeaks:
It's an old car so it will rattle. I know that. Still, I think *some* of the noise is coming from the windows against the window seals (they are sticking slightly) and from the doors against the door seals (same thing). If I open and close all of the doors and all of the windows I seem to break the "seal" which has bonded everything together a tiny bit. Then the car feels a bit tighter. Is there any product that will sort of "re-lube" the rubber a bit so that the doors and windows don't stick themselves to the rubber over a period of a day or two?
I know that was a lot of questions, and I thank everyone in advance for taking the time to read through this!
bvz is offline   Reply With Quote
Old 01-22-2011, 06:54 AM   #2
kpeng
Banned User
My Ride: E46 330 and E30 325
1. No
2. www.ddmtuning.com
3. Go OEM...www.getbmwparts.com
4. Get it shampooed.
5. Use some Gummi Pflege on the seals...or just replace them ($$$)
kpeng is offline   Reply With Quote
Old 01-22-2011, 07:10 AM   #3
beef1020
My Ride: 00 323i
For headlights, you can buy just the plastic lenses for a cheaper option: http://www.khoalty.com/bmw-e46/light...placement-(oem)
Floor mats: http://www.trademotion.com/partlocat...catalogid=4462
Rear cargo liner they make a nice rubber peice for it: http://www.trademotion.com/partlocat...catalogid=4462
beef1020 is offline   Reply With Quote
Old 01-22-2011, 07:22 AM   #4
jerseyfresh
My Ride: is schwartzed out
Headlight lenses;
Use Bavarian Autosport for finding most of the stuff I'm about to suggest...
On there, you'll find new headlight lenses are $40-a-piece and $22-each for the gaskets...
1) Are sedan lights compatible with the touring? That's a Negative Ghostrider...
2) How cheap can I go Dirty cheap on eBay, but that's mostly garbage, so you get what you pay for...
The boy in me really really wants Xenons and Angel Eyes but the bill paying adult is doing his best to smack that boy down. Xenon's are a plus, cheap AE's are boy racer ghey in most circumstances
Do AE look stupid with halogens? Yes
Are there any more or less "stock" replacements that are cheaper?(obviously without the AE) P46's
If I do go nuts and decide to get Xenons, are they a plug in replacement for the current lamps or do I have to worry about error codes and the like?Bimmian has plug-n-play kits for $179 >>> but definitely don't even consider them in a non-projector headlight assembly, because it'll just scatter light everywhere... plus, we'll all hate you for blinding us.
I have, like, 30 seconds of spare time per week and can't really be doing anything that takes more than a screwdriver to implement. - Basically I am cheap, but not cheap enough to try my luck with no-name lights from eBay. So what is the next best option? P46's are going to run about $500 with halo's... that's the cheapest non-OEM option... as it won't require a new LCM or reflash
Floormats:
Bavarian has new mat sets for between $60-150 >>> lots of choices... too many to list.
I assume the touring uses the same mats as a sedan, correct? yup
I'd get one of the weather tech ones so you don't have to worry about sh*t permanently destroying the back carpet
Rattles and squeaks with windows:
If the seals are totally dried out and cracked, just replace them... they're pretty cheap...
If they aren't that torn up, just use some diluted Simply Green to clean any residual gunk that's built up on them, then use some rubber/vinyl conditioner from Meguire's... It's like $15 a bottle.
Originally Posted by trhine View Post
FYI you look like a over weight fortune cookie.
^^^Directed @Kpeng^^^
jerseyfresh is offline   Reply With Quote
Old 01-22-2011, 09:59 AM   #5
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
How are they not compatible? Aren't they both prefacelifted?
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 01-22-2011, 12:15 PM   #6
rbalazsi
My Ride: 323iT, 330Cic
For the headlights... yes, they are compatible.
The OE parts are identical on realoem.com
...and for future reference, the touring and sedan are essentially the same car up until the B pillar anything past that and the parts are different.
Also, the Khoalty link seems broken; but I bought some new covers for mine from Pelicanparts for $33.50 each.
Parts 63-12-8-380-189 & 63-12-8-380-190 are what you'd need.
As for the mats, I've been looking at some of the ones that beef1020 linked to myself.
rbalazsi is offline   Reply With Quote
Old 01-22-2011, 01:09 PM   #7
bvz
Thanks for all the info!
I just saw this DIY for replacing lenses:
http://forum.e46fanatics.com/showthr...highlight=lens
is it really that simple? If so, that's the way I'm gonna go.
Old 01-22-2011, 01:10 PM   #8
mvrk10256
My Ride: E30 325i
yup replacing lenses is a 20 minute job.
Old 01-22-2011, 01:27 PM   #9
SalM
My Ride: Shhh
Originally Posted by kpeng View Post
1. No
Yes, Kpeng wins again!
SalMPhotography
SalM is offline   Reply With Quote
Old 01-22-2011, 01:32 PM   #10
bvz
Brilliant!
And thanks for all the links on the floormats and the Gummi Phlege. I'm gonna order all of this tonight or tomorrow.
Old 01-22-2011, 03:05 PM   #11
Stickbuilder
My Ride: Touring, and others
I bought the originals from BavAuto. Mine came with the new hook and loop pads that insert into the carpet. The cargo area mat is also available from BavAuto. My 2000 Touring is rattle free. I don't think I've ever heard a noise from the car.
[/SIGPIC]I'm fluent in 3 languages:
English
Sarcasm
Profanity
Stickbuilder is offline   Reply With Quote
Old 01-22-2011, 04:11 PM   #12
Jaundiced Outlook
My Ride: has a tailgate
Replacing the lenses are one of the first things I did for my wagon when I bought it - the difference is remarkable and worth the $$$. Thought about trying to polish them, but the old ones were pretty haggled and I'm lazy.
Although my cargo area carpet is in good shape, I'm planning on buying a WeatherTech mat to keep it that way when I'm toting fertilizer or such. BMW makes an OEM mat, but I've been pleased with the fitment and durability of WeatherTech mats in other vehicles.
Jaundiced Outlook is offline   Reply With Quote
Old 01-22-2011, 04:23 PM   #13
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Yes, they are compatible, since you are in Oakland, and we're in Concord, please drive on over so we can show you the various options, we even have just covers for you.
See response to #1 about driving over Because you are giving it to folks that are a little older, you really should consider the xenons as an option, better light output especially as your eyes age and become a little less capable, is a great way to increase their safety for minimal $.
Floormats:
Get all weather mats if you can help it.
My wife purchased the OE one from BMW, it works well and is designed to fit exactly, it may be more costly, so look at Tischer to get a good deal on one.
Already covered by others, it's a good choice.
It's a 5 minute job if you have done it before, and 20 minutes if you haven't.
Brilliant!
Give us a call on Monday or if you have time, drop on in 10am-5pm.
Address is easily found on google maps by typing umnitza in the search.
Old 01-23-2011, 12:38 AM   #14
bvz
Hey there umnitza,
I'll be giving you a call this week. I like the idea that you are local plus you seem to get pretty decent press here. I would love to swing by if I can but that will depend on my work schedule.
Thanks everyone for the great advice.
floormats, headlights, rattles, touring
