Sponsored by BimmerWorld
Old 01-22-2011, 02:22 PM   #1
triumphsix
My Ride: 2001 330ci
Question Converting Koni yellow to coil-over
So I'm thinking of converting my stock springs with Koni yellows to coil-overs using either the Ground-Control coil over kit, or TC Kline's conversion kit. Has anyone done this with either? It sounds like the "stock" type spring seat on the front struts must be removed. Is this a PITA? I'm planning on running some agressive spring rates ~600 front, 700 rear for some AutoX action. This must be right at the limit of the Koni Yellows... comments?
Thanks!
triumphsix is offline   Reply With Quote
Old 01-26-2011, 09:26 PM   #2
ultraviolet_m
My Ride: E46 325 CI
If u r with konis u need to modify the gc spring seats. U need to cut then a bit, but besides that the stick spting seats are coming out really easy
Pending Current Projects - Full White LED Interior(done)/ ZHP Suspension & Ground Control adjustable coilovers(done)/ Black CF window trim wrapping(almost..)/ ECIS CAI filter replacement(done)/ Sprint Booster(done)
ultraviolet_m is offline   Reply With Quote
Old 01-31-2011, 09:54 PM   #3
triumphsix
My Ride: 2001 330ci
All right, thanks! What would be best to cut the gc spring seats with; sawsall, or is that too ghetto?
Old 02-01-2011, 09:40 AM   #4
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Make sure you talk to GC about the options. Their custom Konis have lower spring seats than standard ones, so it will limit how much you want to drop the car (if that's your aim).
Old 02-01-2011, 02:24 PM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Koni with Ground Control sleeves is one of the most renowned, cost effective track setups you can buy. Just be sure to speak with Ground Control's representatives to know what's necessary to make them work.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-03-2011, 08:16 AM   #6
quicksilver69
My Ride: 328Ci
http://volvospeed.com/install_perfor...coilovers.html
quicksilver69 is offline   Reply With Quote
coilovers, ground control, koni
