E46 Xi Forum
Old 01-28-2011, 09:28 PM   #21
TX_Bullet
My Ride: 2001 325Xi
I'm buying it. How do you install that kit though. Do you need that glue they sell?
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 01-28-2011, 10:20 PM   #22
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
not sure how to install the add ons but watch out for $100 in shipping costs..
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 01-29-2011, 12:06 AM   #23
TX_Bullet
My Ride: 2001 325Xi
I was thinking that would happen. Ill look further into it.
I really just want a front lip or zhp
The Mods
Power Flex FCAB
Old 01-29-2011, 07:46 AM   #24
Rickna
My Ride: '01 330xi - '09 IS-F
"Don't glue it-screw it" LOL
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 01-31-2011, 05:04 PM   #25
TX_Bullet
My Ride: 2001 325Xi
30 for the kit but 90 to ship it.....dam
Better off saving up for a bumper
The Mods
Power Flex FCAB
Old 02-01-2011, 07:10 PM   #26
BlackJesus
My Ride: 03 Vert Tiag M3
My springs should be coming in this week, what did you use to make the rear rubber pads smaller?
03 M3 Tiag Vert
BlackJesus is offline   Reply With Quote
Old 02-01-2011, 09:47 PM   #27
TX_Bullet
My Ride: 2001 325Xi
1/4" rubber mat. You should be able get some from home depot. It's usually on a big roll and you just cut what you need.
All you need to do is cut 2 6" circles and a 1 1/2" hole in the middle of each circle
The Mods
Power Flex FCAB
Old 02-02-2011, 09:29 PM   #28
SILVRRONIN
My Ride: 2003 325.xit
ok.. I have been debating on wether or not to install the HR springs on my new shocks on my touring,,,my only concearn was the front axles...any grinding? increased wear and tear due to the compromise on the shafts? the lowering have any negative effect on the axles in relationship to the transmission?...it looks awesome!..i am dying to do it but I dont want to ruin my gearbox, Cv axles etc... it would look soo godd on my touring. I cannot wait to get back to the states......
SILVRRONIN is offline   Reply With Quote
Old 02-02-2011, 09:30 PM   #29
SILVRRONIN
please fill me in on any changes with the new srings and the lowering......
Old 02-02-2011, 10:25 PM   #30
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
Me too!
drumbum624 is offline   Reply With Quote
Old 02-03-2011, 08:59 AM   #31
TX_Bullet
My Ride: 2001 325Xi
Wear on axle boots? Assumed not quantified
Excess wear to drivetrain......um no
I recommend different strut than stock. If I hit a pot hole or good bump in the road I can hear the fronts bottom out
The Mods
Power Flex FCAB
Old 02-03-2011, 09:08 AM   #32
SILVRRONIN
springs...
You can hear the front bottom out?
nah.. i wil pass!..the bilstein shocks and schmeidman stock springs wil go with my ride...bottoming out isnt good and I live in New Orleans now...ROADS HERE SUK!!!!
thanks for the feedback!
Old 02-03-2011, 09:13 AM   #33
Rickna
The debate on wear vs lowering is as old as dirt. If you're lowering with H&R or Eibach, no worries.
Lowering springs on stock shocks-again debatable. It's been said that stock shocks don't have the same travel characteristics as Bilstien or Koni. Yet there are some that claim to have no premature shock blow-out.
2001 BMW 330xi
2009 Lexus IS-F
Old 02-03-2011, 09:20 AM   #34
Rickna
You're not alone, roads almost everywhere suk.
2001 BMW 330xi
2009 Lexus IS-F
Old 02-03-2011, 09:21 AM   #35
TX_Bullet
My Ride: 2001 325Xi
Right! If you run bilstein you will be good. In all honestly it should be done regardless but running stocks will work for a while unless your bottoming constantly
The Mods
Power Flex FCAB
Old 02-03-2011, 09:30 AM   #36
Rickna
My setup is Eibach on Koni-very comfy.
2001 BMW 330xi
2009 Lexus IS-F
Old 02-07-2011, 09:40 PM   #37
EDness
My Ride: 2004 BMW 325xi
where did you guys buy the H&R springs?
EDness is offline   Reply With Quote
Old 02-07-2011, 11:10 PM   #38
TX_Bullet
My Ride: 2001 325Xi
Do some searching..... there are a few members and don't forget our sponsors
The Mods
Power Flex FCAB
Old 03-04-2011, 08:46 PM   #39
SharkmanBMW
My Ride: 03 330xi, 4th bimmer
Send a message via MSN to SharkmanBMW
@TX - what is the purpose of using a smaller spring pad? Is it just so the back sits lower and looks good? OR is there another benefit? I am trying to solve rear end clunks/shocks blowing, is it possible the OEM thick pad is causing the problems?
History: After finding broken rear OEM springs, I started with H&R on OEM shocks, was OK for awhile but started clunking.
So I upgraded to H&R on Bilstein Sport, looks sexy, handling is spectacular, but on bad roads it is a nightmare. I actually keep blowing rear shocks, which destroy the OEM shock mounts, so now I installed Rogue Engineering RSMs and have 2 "new & improved" Bilstein rears on the way, fingers crossed the failures end here.
If it continues, I may swap the springs for Eibach in hopes they are softer, maybe not quite as much of a drop - just enough to not blow shocks on these bad roads.
H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs
SharkmanBMW is offline   Reply With Quote
Old 03-05-2011, 01:27 AM   #40
TX_Bullet
My Ride: 2001 325Xi
Yes the smaller rear pads were installed to eliminate most of the notorious h&r rake.
I'm also running OEM struts all around and I can here them slowly blowing.
I think ill go bilstein HD all around
The Mods
Power Flex FCAB
